Build 1623: Sort By changes to "None" after restarting Daminion
WilfriedB
OK so that customer with a team of 50 users has CHOSEN to have a massive catalog when they could have segmented it. Their choice, their problem. Why do the rest of us have to suffer because of the poor choices of ONE customer.
Why don't you suggest to that customer that they come onto this forum and debate the issue with those of us who now have to live with the consequences of their poor decisions.
Meanwhile WE put our ideas on here and discuss them. And we go with the majority. We wouldn't have said NO to their suggestion but we sure as hell would have proposed that it be a user option - not exactly rocket science is it?
Do you not want the rest of us as users anymore?
  • Upvote 2
The guys have fixed the sorting issue in the latest build.
1. You need to install Daminion 5.5.1736.
2. Go to this path on your PC: C:\Users\USER_NAME\AppData\Roaming\Daminion Software\Daminion\1.0
3. Open the file "Settings.xml"
4. Find the string "<setting name="RestoreSorting" serializeAs="String"> "
5. By default the value of this string s the following:
<value />
</setting>
6. You need to edit this string to get the following result:
<value>True</value>
</setting>
7. Save changes
8. Restart Daminion. Sorting order will be preserved since now.
  • 3 weeks later...
  • 2 years later...
  • 3 years later...
Hi!
I'm using build 3257 and it is not saving the "Sort by" selection when reopening, checked the Settings.xml file and it still has the RestoreSettings value that used to work:
        <value>True</value>
      </setting>
Anyone else experiencing this?
Thanks!
Regards
On 11/11/2023 at 4:10 AM, exterminador said:
Hi!
        <value>True</value>
      </setting>
Thanks!
Regards
Hello, try to select the desired sorting and close the catalog via File>Close Catalog. The thing is that we save the settings either at logout or by closing the catalog. If you just close the application, the settings will not be saved. Users of the lite version do not have a logout button, so there may be problems with saving.
