exterminador Posted June 27, 2022 Report Share Posted June 27, 2022 Hi there, In 2693 I found that to rescan a folder, I need to select the "Rescan folders..." option twice in order for Daminion to scan the folder. I use the manual rescan on folders (I have no automatic scan enabled). Steps to reproduce: Right clic on a folder and select "Rescan folders..." Select "Rescan (F6)..." 3. It quickly shows the last (previously) imported files and finishes the import process, no new files are imported 4. Right clic on the same folder as step 1 and select "Rescan folders..." 5. Select "Rescan (F6)..." 6. Now it import the new files and after a while, it shows the list of imported files Has anyone seen this behavior? Thanks! Regards Quote Link to comment Share on other sites More sharing options...
Daria Kotilainen Posted June 28, 2022 Report Share Posted June 28, 2022 Hi Exterminador, please try to install 2734 - this has been fixed. Don't forget to create the backups prior to the upgrade Daria Quote Link to comment Share on other sites More sharing options...
exterminador Posted July 2, 2022 Author Report Share Posted July 2, 2022 Hi Daria, thanks a lot for following up, I installed 2734 but it still happens (I have to select "Rescan folders..." twice for Daminion to scan the folder). Thanks! Quote Link to comment Share on other sites More sharing options...
Uwe Posted July 3, 2022 Report Share Posted July 3, 2022 Confirmed Quote Link to comment Share on other sites More sharing options...
Daria Kotilainen Posted July 4, 2022 Report Share Posted July 4, 2022 Hi Uwe and Nabani, This is very strange, I cannot reproduce it in 2734. I've also tried on my personal laptop where I've got 2743 - same thing, Rescan works at the first attempt. Please give a try to 2743. If it happens again, please record a screencast for me Kind regards, Daria Quote Link to comment Share on other sites More sharing options...
Lenni Posted August 2, 2022 Report Share Posted August 2, 2022 Hi, I can confirm it also. In addition, every now and then Daminion also crashes during Rescan. Running 2743. Quote Link to comment Share on other sites More sharing options...
Stephen Posted August 8, 2022 Report Share Posted August 8, 2022 Just to say I am running 2743 and I have to do the double folder scan to import files though haven't had a crash to date Quote Link to comment Share on other sites More sharing options...
lintujuh Posted August 12, 2022 Report Share Posted August 12, 2022 I'm running 2743, and I have to select Rescan Folders twice, to rescan. I'm not having any crashes during the rescan. Sometimes the rescan works on the first try, but most of the times not. Quote Link to comment Share on other sites More sharing options...
Uwe Posted August 14, 2022 Report Share Posted August 14, 2022 Hi, First F6 - it shows the last imported items Second F6 - the rescan starts Regards, Uwe Quote Link to comment Share on other sites More sharing options...
Daria Kotilainen Posted August 15, 2022 Report Share Posted August 15, 2022 Hi team, please try installing the latest build (make sure your free updates are active!) and let me know if you experience the same thing. Kind regards, Daria Quote Link to comment Share on other sites More sharing options...
lintujuh Posted August 15, 2022 Report Share Posted August 15, 2022 The issue is still in 2784. It worked as expected when I launched rescan the first time. But on the next rescans I had to rescan twice or thrice. Quote Link to comment Share on other sites More sharing options...
Daria Kotilainen Posted August 16, 2022 Report Share Posted August 16, 2022 @Oleg.Rosscould you please double-check it again? I was able to reproduce the issue on one of my catalogs today. Kind regards, Daria Quote Link to comment Share on other sites More sharing options...
exterminador Posted August 18, 2022 Author Report Share Posted August 18, 2022 Hi Daria, everybody, just to confirm this still happens in 2784. What I did: 1) added new files in folder A 2) right click -> rescan 3) the process finished and showed the previously imported files 4) right click -> rescan 5) it imported and showed the new files from folder A 6) added new files in the same folder A 7) right click -> rescan 8 ) the process finished and showed the imported files of step 5 <- repeated steps 7 and 8 for 3 times, same result 9) added files to a different folder (folder B) 10) on folder B, right click -> rescan 11) right click -> rescan 12) the process finished and showed the imported files of step 5 13) on folder B, right click -> rescan 14) it imported and showed the new files from folder B 15) on folder A, right click -> rescan 16) the process finished and showed the imported files of step 14 17) on folder A, right click -> rescan 18) it imported and showed the new files from folder A (added in step 6) I have had no crashes, though. Thanks! Quote Link to comment Share on other sites More sharing options...
Daria Kotilainen Posted August 19, 2022 Report Share Posted August 19, 2022 Hi, yes, I was able to reproduce this issue. @Oleg.Rossplease reopen the issue Quote Link to comment Share on other sites More sharing options...
Oleg.Ross Posted August 23, 2022 Report Share Posted August 23, 2022 On 8/19/2022 at 12:32 PM, Daria Kotilainen said: Hi, yes, I was able to reproduce this issue. @Oleg.Rossplease reopen the issue Already fixed in an upcoming release. Quote Link to comment Share on other sites More sharing options...
Daria Kotilainen Posted August 23, 2022 Report Share Posted August 23, 2022 thank you Oleg! Quote Link to comment Share on other sites More sharing options...
exterminador Posted August 23, 2022 Author Report Share Posted August 23, 2022 Thanks Oleg, Daria! 🙂 Quote Link to comment Share on other sites More sharing options...
