kalain Posted April 24, 2019 Report Share Posted April 24, 2019 Hi, If you close Properties panel by closing cross You get this, and it's not possible to reduce empty space to display more thumbnails When you display map and close it with closing cross You get this (which is ok) would be nice to have same behaviour (as closing window panel) when you close properties panel Quote Link to comment Share on other sites More sharing options...
Uwe Posted April 24, 2019 Report Share Posted April 24, 2019 I dont have this problem with the Properties Panel in the 1934 build (Team Server version). If I close the panel using the cross the Thumbnail Window expands to the end of the client window. regards, Uwe Quote Link to comment Share on other sites More sharing options...
kalain Posted April 24, 2019 Author Report Share Posted April 24, 2019 Strange. Build 1934 Standalone and Win 8.1 Quote Link to comment Share on other sites More sharing options...
Uwe Posted April 24, 2019 Report Share Posted April 24, 2019 Win10Pro version 1809 Quote Link to comment Share on other sites More sharing options...
WilfriedB Posted April 24, 2019 Report Share Posted April 24, 2019 21 minutes ago, Uwe said: I dont have this problem with the Properties Panel in the 1934 build (Team Server version). If I close the panel using the cross the Thumbnail Window expands to the end of the client window. I noticed this a long ago for the first time and it still happens with Build 1934. I assume it is the depending on the size of the display (mine is 1920x1080). My "solution" is to either keep the properties panel docked, or - when I need more real estate on the screen, to drag the panel free floating to the bottom of the screen. I consider free floating anyway as a better choice for Tags, Folders and Map, but most of the I keep properties docked to the right. Tip: If I quickly want to see the properties of a single image, I open it in full screen with properties hidden, but moving the mouse to right shows the properties temporarily. Quote Link to comment Share on other sites More sharing options...
WilfriedB Posted April 24, 2019 Report Share Posted April 24, 2019 This is the usual layout of my display. At the marked area on the bottom, you can the title bars of the Tags, Folders (includes Keywords) and Map panels, which I drag up only when needed. Quote Link to comment Share on other sites More sharing options...
Uwe Posted April 24, 2019 Report Share Posted April 24, 2019 ok, I'm not at home this week and I'm working now on an old laptop (Thinkpad T61p, 1920x1200, Nvidia Quadro FX570M) and docked panel. At home I'm working with free floating panels which are on a second screen. regards, Uwe Quote Link to comment Share on other sites More sharing options...
WilfriedB Posted April 24, 2019 Report Share Posted April 24, 2019 Just to confirm Alain's observation: Quote Link to comment Share on other sites More sharing options...
kalain Posted April 24, 2019 Author Report Share Posted April 24, 2019 Here is another try with Map panel and Properties panel displayed (and docked) If you close Properties panel (with closing cross) you get this (ok, no empty space) : Now, if you close Map panel, you get this (with empty space : not ok) : Looks like this empty space is linked after closing properties panel (with closing cross). Regards Quote Link to comment Share on other sites More sharing options...
kalain Posted April 24, 2019 Author Report Share Posted April 24, 2019 31 minutes ago, WilfriedB said: I noticed this a long ago for the first time and it still happens with Build 1934. I assume it is the depending on the size of the display (mine is 1920x1080). Same for me, 1920*1080. Quote Link to comment Share on other sites More sharing options...
Daria Kotilainen Posted November 16, 2019 Report Share Posted November 16, 2019 6.2.1997 fixed Quote Link to comment Share on other sites More sharing options...
kalain Posted May 5, 2020 Author Report Share Posted May 5, 2020 Hi, Bug still here in build 2099 when you close Properties panel. (Win 10) Quote Link to comment Share on other sites More sharing options...
Daria Kotilainen Posted May 12, 2020 Report Share Posted May 12, 2020 Hi Alain, Unfortunately, cannot reproduce this behavior either in the local, or shared catalog. Kind regards Daria Quote Link to comment Share on other sites More sharing options...
WilfriedB Posted May 13, 2020 Report Share Posted May 13, 2020 11 hours ago, Daria Kotilainen said: Unfortunately, cannot reproduce this behavior either in the local, or shared catalog. Daria, did you verify this with a display size of 1920*1080? I can confirm, this still happens in Build 2099: Starting point, the properties panel takes approximately the same space as one thumbnail: After closing the properties panel, thumbnail increases the size, but does not completely fill the window. So there is unused space on the right: After opening the Properties panel again, it is wider than it was before closing, thus the thumbnail area becomes smaller and the selected thumbnail moves to the next row: Quote Link to comment Share on other sites More sharing options...
Uwe Posted May 13, 2020 Report Share Posted May 13, 2020 Hello, the same wrong behaviour for 1920x1200. Regards, Uwe Quote Link to comment Share on other sites More sharing options...
kalain Posted May 13, 2020 Author Report Share Posted May 13, 2020 The only way (I have found) to close correctly properties panel is to undock it and after close it. Quote Link to comment Share on other sites More sharing options...
Daria Kotilainen Posted May 13, 2020 Report Share Posted May 13, 2020 Hi guys, Yes, I tried with 1920x1080, this is my default resolution. Would you please try to install 2120? Quote Link to comment Share on other sites More sharing options...
Uwe Posted May 13, 2020 Report Share Posted May 13, 2020 Hi Daria, I have the build 2120 and the bug is there. regards, Uwe Quote Link to comment Share on other sites More sharing options...
kalain Posted May 13, 2020 Author Report Share Posted May 13, 2020 3 hours ago, Daria Kotilainen said: Hi guys, Yes, I tried with 1920x1080, this is my default resolution. Would you please try to install 2120? Link point to Server version! Is there a link toward stand alone version ? Quote Link to comment Share on other sites More sharing options...
Daria Kotilainen Posted May 13, 2020 Report Share Posted May 13, 2020 2 hours ago, kalain said: Link point to Server version! Is there a link toward stand alone version ? Please download it from here Quote Link to comment Share on other sites More sharing options...
kalain Posted May 14, 2020 Author Report Share Posted May 14, 2020 10 hours ago, Daria Kotilainen said: Please download it from here Ok, 2120 build in Stand Alone version works correctly. I played a bit around and couldn't reproduce anymore the problem. Looks like it's fixed. Quote Link to comment Share on other sites More sharing options...
WilfriedB Posted May 14, 2020 Report Share Posted May 14, 2020 19 hours ago, Daria Kotilainen said: Yes, I tried with 1920x1080, this is my default resolution. Would you please try to install 2120? Seems, Daria, Uwe and Alain are all correct: If you close the client, while the properties panel is closed, then start the client again, it worked fine for me (with build 2120) If you close the client, while the properties panel is docked at the right, then start the client again, I see the same behavior as described above. Quote Link to comment Share on other sites More sharing options...
WilfriedB Posted May 14, 2020 Report Share Posted May 14, 2020 And by the way, since this morning, I get this error each time, I try to open any Daminion Web site, as well a similar message when I first started the client (Build 2099): This server could not prove that it is www.daminion.net; its security certificate expired in the last day. This may be caused by a misconfiguration or an attacker intercepting your connection. Your computer's clock is currently set to Thursday, May 14, 2020. Does that look right? If not, you should correct your system's clock and then refresh this page. NET::ERR_CERT_DATE_INVALID Quote Link to comment Share on other sites More sharing options...
Daria Kotilainen Posted May 14, 2020 Report Share Posted May 14, 2020 Hi guys, could you please try to click Window > Reset window layout and report back to me if it helped. Kind regards, Daria Quote Link to comment Share on other sites More sharing options...
kalain Posted May 14, 2020 Author Report Share Posted May 14, 2020 Here is some more investigations (stand alone 2120). When I close properties panel it closes correctly. Now, if I open Properties panel window, it's still ok. Now, if I undock and redock windows, Properties panel doesn't close correctly (Still an empty grey space displayed) If I click Window > Reset window layout, now properties panel closes correctly. Quote Link to comment Share on other sites More sharing options...
