aebe_ch Posted February 18, 2024 Report Share Posted February 18, 2024 On 11/13/2023 at 10:36 AM, Oleg.Ross said: Hello, try to select the desired sorting and close the catalog via File>Close Catalog. The thing is that we save the settings either at logout or by closing the catalog. If you just close the application, the settings will not be saved. Users of the lite version do not have a logout button, so there may be problems with saving. Same here, that worked. But please Daria, why can't this be solved in a more user-friendly way ? 1 Quote Link to comment Share on other sites More sharing options...
Volker Posted April 16, 2024 Report Share Posted April 16, 2024 Meanwhile I am on 9.0.0 build 3406. In my settings I have <setting name="RestoreSorting" serializeAs="String"> <value>True</value> </setting> But, the sort order is gone each time I restart Daminion client. Quote Link to comment Share on other sites More sharing options...
Daria Kotilainen Posted April 16, 2024 Report Share Posted April 16, 2024 Hi Volker, Please try to do Log Out, then close the app just once. This should help to remember the settings for the future, even if you will be exiting the catalog by simply closing the app. Kind regards, Daria Quote Link to comment Share on other sites More sharing options...
Volker Posted April 16, 2024 Report Share Posted April 16, 2024 Hi Daria, thank you for your reply. The workaround you suggested isn't working properly. Once I managed to set the sort order to "Filename" it will always be on "Filename" after a restart of the application. Sometimes you change the sort order and forget to logout from the catalog in order to save the setting and the chosen sort order is gone. This is not very user friendly. I can't understand why it is so difficult (or seemingly impossible) to remember such a setting. You have to consider that this issue is now more than 7 years old! Best regards, Volker Quote Link to comment Share on other sites More sharing options...
Daria Kotilainen Posted April 18, 2024 Report Share Posted April 18, 2024 Hi Volker, I will highlight this issue with the developers tomorrow and see if it can be permanently fixed. My sincere apologies for the inconvenience! Kind regards, Daria Quote Link to comment Share on other sites More sharing options...
Rupert Posted January 22, 2025 Report Share Posted January 22, 2025 Since version 10.0 the option to sort is gone. It's "none" and grayed out and I have no chance to change it. When I use some kind of filters, the sorting works properly. But when I remove all filters, it's "none" and gray again. Please fix that. I don't want to use filters all the time. Thanks! Kind regards, Rupert Quote Link to comment Share on other sites More sharing options...
Daria Kotilainen Posted January 22, 2025 Report Share Posted January 22, 2025 Hello Rupert, this functionality has been changed. Now sorting is only available if you made a query. Sorting on the whole database was disabled due to slowness of the results display on large databases (1 mln and more) Quote Link to comment Share on other sites More sharing options...
Rupert Posted April 7, 2025 Report Share Posted April 7, 2025 Ok, I just tested it with a query that selects all my photos (60k) and the sorting takes less than a second. So can you please add a flag or something, where people with strong computers or small databases can re-activate the sort for all pictures? THX, Rupert Quote Link to comment Share on other sites More sharing options...
Daria Kotilainen Posted April 7, 2025 Report Share Posted April 7, 2025 Hi Rupert, This is the updated functionality in the new version. If you still need to sort the whole catalog, please expand the folders tag, select the top folder and the sort will be available again. Unfortunately, the flag cannot be added now, but we can consider it for the future Quote Link to comment Share on other sites More sharing options...
