Connection to shred catalog
Volker
Hi Volker,
if the catalog is closed: all user are logged out. Please open the catalog again. If you are not asked to enter user name and password you set the flag "remember me" in a previous login procedure.
Now, in the open catalog in the upper right corner is the information: "angemeldet als xxx or logged in as xxx". Please click on this text and the select "logout". The next time you open the catalog you will be asked to enter user name and password.
thank you for clarifying this point. Maybe I was confused by the description under https://www.daminion.net/feature-tour/daminion-server/control-access-to-your-content . There should be a hint that this feature depends on the editon you use.
I'll put a note about the server edition to the page describing the Access Control feature. Thanks for the note!
