_noel_ Posted September 1, 2013 Report Share Posted September 1, 2013 (edited) Hello to all, after some months of absence and some Daminion versions, I'm back again :-) version 875 seems to have problems with german umlauts / mutated vowels (like some daminion versions of former times ...). (similar to this thread) I've geotagged some images (Nikon D800 & D80 NEFs, data written to NEFs, no XMP sidecar) with geosetter (v 3.4.38, exiftool version 9.35). Daminion shows the state "Baden-Württemberg" as "Baden-Württemberg", also all other new geo tags with umlauts are crippled. I forced Daminion to use the newest exiftool version, but this did not fix the problem. Also if I tag an image with "Baden-Württemberg" within Daminion, after "Write tags" / "Read tags" with Daminion the umlaut is crippled. Can this be fixed again? Addendum: the problem is with the NEFs, JPGs, which have been extracted from the NEFs are ok, the Umlauts are not crippled ... Regards Eberhard Edited September 1, 2013 by _noel_ 1 Quote Link to comment Share on other sites More sharing options...
Uwe Posted September 1, 2013 Report Share Posted September 1, 2013 Hello, the problem doesn't appear in the server version. Regards, Uwe Quote Link to comment Share on other sites More sharing options...
rene Posted September 1, 2013 Report Share Posted September 1, 2013 Hey Uwe, I have the Server Version and I do have that problem. But it is not that important since I write instead of "Ü" "ue" so its working working good like this Quote Link to comment Share on other sites More sharing options...
_noel_ Posted September 1, 2013 Author Report Share Posted September 1, 2013 The bug can be reproduced with other tags too, e.g. with "People" (Tested with Nikon NEFs) Regards Eberhard Quote Link to comment Share on other sites More sharing options...
rene Posted September 1, 2013 Report Share Posted September 1, 2013 On 9/1/2013 at 7:42 PM, _noel_ said: The bug can be reproduced with other tags too, e.g. with "People" (Tested with Nikon NEFs) Regards Eberhard Ok, I mean all Names I enter do not have any mutated words. So in case of Austria (Österreich) I entered "Oesterreich" etc. I guess this is okay. I anyhow thought about making the complete structure in english. regards rene Quote Link to comment Share on other sites More sharing options...
_noel_ Posted September 1, 2013 Author Report Share Posted September 1, 2013 On 9/1/2013 at 7:45 PM, Rene said: Ok, I mean all Names I enter do not have any mutated words. So in case of Austria (Österreich) I entered "Oesterreich" etc. I guess this is okay. I anyhow thought about making the complete structure in english. regards rene a DAM software, which is not able to deal with other languages / codepages than english is IMHO - sorry to say that - valueless. Regards Eberhard Quote Link to comment Share on other sites More sharing options...
rene Posted September 2, 2013 Report Share Posted September 2, 2013 I mean, it should be fixed, but i guess there are much more important features that need to be implemented Quote Link to comment Share on other sites More sharing options...
_noel_ Posted September 2, 2013 Author Report Share Posted September 2, 2013 On 9/2/2013 at 8:21 AM, Rene said: I mean, it should be fixed, but i guess there are much more important features that need to be implemented It's a bug, not a feature :wink:... and it has been working a few versions before. I think, the issue can be fixed with low effort ... Regards Eberhard Quote Link to comment Share on other sites More sharing options...
Uwe Posted September 2, 2013 Report Share Posted September 2, 2013 Hello, I've tested it again with the server version and a DNG item. I entered the German-Umlauts "ÄÖÜäöü" in the Title, Description, Keywords and Places Tags - no problem in build 875. I use Win7-64bit German. Regards, Uwe Quote Link to comment Share on other sites More sharing options...
_noel_ Posted September 2, 2013 Author Report Share Posted September 2, 2013 On 9/2/2013 at 9:41 AM, Uwe said: Hello, I've tested it again with the server version and a DNG item. I entered the German-Umlauts "ÄÖÜäöü" in the Title, Description, Keywords and Places Tags - no problem in build 875. I use Win7-64bit German. Regards, Uwe Hello Uwe, Yes, DNG seems to work, but other RAWs, e.g. NEFs do not ... Regards Eberhard Quote Link to comment Share on other sites More sharing options...
_noel_ Posted September 3, 2013 Author Report Share Posted September 3, 2013 I've installed the RC2 (Build 833): With this version the mutated vowels within NEFs are OK. Regards Eberhard Quote Link to comment Share on other sites More sharing options...
_noel_ Posted September 5, 2013 Author Report Share Posted September 5, 2013 @Murat: Is this problem understood or do you need more input / testing / ect. from me ? Regards Eberhard Quote Link to comment Share on other sites More sharing options...
talvistup Posted September 20, 2013 Report Share Posted September 20, 2013 I will add my two cents worth of similar troubles. On Estonian keyboards the usual way to get letters š and ž is to use combinations Alt Gr+s and Alt Gr+z respectively. However, Daminion seems to have a problem with entering the lowercase ž into the fields. After you enter it, all the previously entered characters besides the first one in the field disappear. Interestingly enough the uppercase Ž doesn't cause a similar problem. Quote Link to comment Share on other sites More sharing options...
lintujuh Posted September 22, 2013 Report Share Posted September 22, 2013 I am using umlauts in DAM without problems, I have places like Jämsä and Mänttä. My guess is that your problem is using character set Latin-1 in one (Daminion) software and UTF-8 (exiftool) in the other. Check the exiftool FAQ about charsets. Quote Link to comment Share on other sites More sharing options...
_noel_ Posted September 22, 2013 Author Report Share Posted September 22, 2013 On 9/22/2013 at 3:06 PM, Juha said: I am using umlauts in DAM without problems, I have places like Jämsä and Mänttä. My guess is that your problem is using character set Latin-1 in one (Daminion) software and UTF-8 (exiftool) in the other. Check the exiftool FAQ about charsets. I write and read with Daminion, and with Exiftool GUI within Daminion. Murat has got images and screencast from me, it's a problem within Daminion. Same images (NEF) work with Daminion RC1 build 833. Regards Eberhard Quote Link to comment Share on other sites More sharing options...
Murat Posted September 24, 2013 Report Share Posted September 24, 2013 The problem was fixed. A new version will be available on this week. Thanks for the info about this bug! Quote Link to comment Share on other sites More sharing options...
_noel_ Posted September 24, 2013 Author Report Share Posted September 24, 2013 I'll test the new version next week after my leave ... Regards Eberhard Quote Link to comment Share on other sites More sharing options...
_noel_ Posted October 3, 2013 Author Report Share Posted October 3, 2013 Hello, Tested with v888: the bug with the mutated vowels is fixed , issue can be closed. Regards Eberhard Quote Link to comment Share on other sites More sharing options...
