Connections not properly closed in 7.0.0.2433
Volker
after upgrading to the recent 7.0 I observe have these problems:
  • closing a client takes up to a minutes
  • when restarting the client apllication it takes several minutes until I can connect to the catalog again, because the maximum number of connections has been reached.
Considering the new interface I would like to revert a previous version. Is there a way to do so?
Best regards,
Volker
Thank you for your reply, Daria.
After restarting Daminion server the behaviour is unchanged: closing a client takes a very long time and starting the client doesn't work, because the connection limit has been reached.
The dark view is working partially; just the thumbnail windows is affected.
Volker
When closing the client application I can see a very high CPU usage on the server with one or two of the Postgres processes. In the logs there are lots of syntax errors reported:
ERROR 2021-04-07 21:51:08,175 FtsLoader.RecurrentTask [3] - Npgsql.PostgresException (0x80004005): 42601: Syntaxfehler bei »on«
   bei Npgsql.NpgsqlConnector.<>c__DisplayClass160_0.<<DoReadMessage>g__ReadMessageLong|0>d.MoveNext()
--- Ende der Stapelüberwachung vom vorhergehenden Ort, an dem die Ausnahme ausgelöst wurde ---
   bei System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
   bei System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)
   bei System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
   bei System.Threading.Tasks.ValueTask`1.get_Result()
   bei Npgsql.NpgsqlDataReader.<NextResult>d__44.MoveNext()
   bei Npgsql.NpgsqlDataReader.NextResult()
   bei Npgsql.NpgsqlCommand.<ExecuteReaderAsync>d__102.MoveNext()
   bei Npgsql.NpgsqlCommand.<ExecuteNonQuery>d__92.MoveNext()
   bei Npgsql.NpgsqlCommand.ExecuteNonQuery()
   bei Dapper.SqlMapper.ExecuteCommand(IDbConnection cnn, CommandDefinition& command, Action`2 paramReader) in /_/Dapper/SqlMapper.cs:Zeile 2797.
   bei Dapper.SqlMapper.ExecuteImpl(IDbConnection cnn, CommandDefinition& command) in /_/Dapper/SqlMapper.cs:Zeile 568.
   bei FtsLoader.CatalogRepository.<>c__DisplayClass12_0.<SaveContent>b__0(IDbConnection connection) in C:\DaminionAutoGit\code\FtsLoader\src\FtsLoader\CatalogRepository.cs:Zeile 79.
   bei FtsLoader.Repository.UsingConnection[T](Func`2 func) in C:\DaminionAutoGit\code\FtsLoader\src\FtsLoader\Repository.cs:Zeile 20.
   bei FtsLoader.CatalogRepository.SaveContent(Int64 mediaItemId, String content) in C:\DaminionAutoGit\code\FtsLoader\src\FtsLoader\CatalogRepository.cs:Zeile 78.
   bei FtsLoader.RecurrentTask.RunAsync(ITask currentTask, IServiceProvider scopeServiceProvider, CancellationToken cancellationToken) in C:\DaminionAutoGit\code\FtsLoader\src\FtsLoader\RecurrentTask.cs:Zeile 72.
  Exception data:
    Severity: FEHLER
    SqlState: 42601
    MessageText: Syntaxfehler bei »on«
    Position: 102
    File: src\backend\parser\scan.l
    Line: 1002
    Routine: scanner_yyerror
If you use PostgreSQL lower than v. 10, please update it.
To upgrade your PostgreSQL version, please follow these steps:
- download PostgreSQL 10 or 12 (https://www.enterprisedb.com/downloads/postgres-postgresql-downloads)
- Create backups of your catalogs in the Daminion server admin panel
- Stop your current PostgreSQL and manually kill all residual processes if any (in TaskManager)
- Run the installation of PostgreSQL and make sure it is being installed to the port 5432
- Once the installation is done, please double-check that only PostgreSQL is running
- Go to Daminion server admin panel > Catalogs > select a catalog > Actions > Restore and restore the catalogs from the backups you created earlier.
- Run Daminion server
Let me know if you have any problems with the process.
Kind regards, Kate
On 4/8/2021 at 11:04 AM, Katerina Karpenko said:
PostgreSQL 10 or 12
Kate, does this mean PostgreSQL is supported and was tested with Daminion? I remember a post where somebody claimed to have seen performance improvements after upgrading to PostgreSQL 12 (or 13?).
