Volker Posted March 16, 2013 Report Share Posted March 16, 2013 There is a problem displaying the Place. Regards, Volker Quote Link to comment Share on other sites More sharing options...
Murat Posted March 18, 2013 Report Share Posted March 18, 2013 Server or local catalog? Quote Link to comment Share on other sites More sharing options...
Volker Posted March 18, 2013 Author Report Share Posted March 18, 2013 Server or local catalog? It's the local installation. Quote Link to comment Share on other sites More sharing options...
Volker Posted March 18, 2013 Author Report Share Posted March 18, 2013 I found out, that I have two Country-tags in the catalog (see screenshot) and the issue only occurs with 'Wiehl'. Quote Link to comment Share on other sites More sharing options...
Murat Posted March 19, 2013 Report Share Posted March 19, 2013 Could you please send me your catalog for analyzing to support at daminion.net? Quote Link to comment Share on other sites More sharing options...
Volker Posted March 19, 2013 Author Report Share Posted March 19, 2013 Could you please send me your catalog for analyzing to support at daminion.net? The catalog is on its way to you. Volker Quote Link to comment Share on other sites More sharing options...
Volker Posted March 23, 2013 Author Report Share Posted March 23, 2013 Hi Murat, do you already have any idea what the problem might be? Regards, Volker Quote Link to comment Share on other sites More sharing options...
Murat Posted March 26, 2013 Report Share Posted March 26, 2013 Volker, could you please update to 757 build. Quote Link to comment Share on other sites More sharing options...
Volker Posted March 26, 2013 Author Report Share Posted March 26, 2013 Hi Murat, I am on 757, but the behaviour did not change. Regards, Volker Quote Link to comment Share on other sites More sharing options...
Volker Posted March 27, 2013 Author Report Share Posted March 27, 2013 760: problem still exists. Regards, Volker Quote Link to comment Share on other sites More sharing options...
Murat Posted March 28, 2013 Report Share Posted March 28, 2013 The problem with duplicate "[Country]" can't be fixed with new version updating because there is a Tag named "[Country]" in your database. Could you please: 1. Update to 761 version 2. Remove the second "[Country]" tag manually. 3. Try to reproduce a case when this tag might appears again (of course without adding it manually :) Quote Link to comment Share on other sites More sharing options...
Volker Posted March 28, 2013 Author Report Share Posted March 28, 2013 Hi Murat, after upgrading to 761 I deleted the second [Country] as suggested and everything seemed to be fine. But when I try to "Add Tag Inside 'Deutschland'" the second [Country] reappears and the new tag (in my case 'Düsseldorf') is under this second [Country]. Regards, Volker Quote Link to comment Share on other sites More sharing options...
Murat Posted March 30, 2013 Report Share Posted March 30, 2013 after upgrading to 761 I deleted the second [Country] as suggested and everything seemed to be fine. But when I try to "Add Tag Inside 'Deutschland'" the second [Country] reappears and the new tag (in my case 'Düsseldorf') is under this second [Country]. Can you please record a short video for me? Quote Link to comment Share on other sites More sharing options...
Volker Posted June 13, 2013 Author Report Share Posted June 13, 2013 Hi Murat, I still have this issue with build 823. Could you please give ma a hint how to record a video? Volker Quote Link to comment Share on other sites More sharing options...
Uwe Posted June 13, 2013 Report Share Posted June 13, 2013 Hi Volker, I use this one: http://camstudio.org/ Regards, Uwe Quote Link to comment Share on other sites More sharing options...
Volker Posted June 14, 2013 Author Report Share Posted June 14, 2013 Thank you, Uwe! Murat, I'll send you the download link for the video by email. Regards, Volker Quote Link to comment Share on other sites More sharing options...
Volker Posted June 21, 2013 Author Report Share Posted June 21, 2013 Hi Murat, any news on this issue? Regards, Volker Quote Link to comment Share on other sites More sharing options...
Volker Posted July 4, 2013 Author Report Share Posted July 4, 2013 Hello Murat, I am now on build 844 and the issue is still the same. Any ideas? Regards, Volker Quote Link to comment Share on other sites More sharing options...
Murat Posted July 5, 2013 Report Share Posted July 5, 2013 Could you please send me a fresh version of your catalog? BTW why did you add Deutschland as a state? Quote Link to comment Share on other sites More sharing options...
Murat Posted July 5, 2013 Report Share Posted July 5, 2013 Thanks for sending us your catalog! Unfortunately I can't reproduce an issue neither with strange Country symbols (according to your initial post) no with duplicate Country tag. Yes, the duplicate [Country] values was existed in your catalog, but after its removal, I can't reproduce a problem when it could appear again. Quote Link to comment Share on other sites More sharing options...
Volker Posted July 5, 2013 Author Report Share Posted July 5, 2013 I made another video showing this behaviour and stored it under www.siebelink.de/daminion/place2.avi . In this example I add 'Test Town' under 'Deutschland', whichresults in a second entry for 'Deutschland'. Rather interesting: when I now delete 'Test Town' and the second entry for 'Deutschland' and make another try to add the town the behaviour is as expected. My impression is, that this only happens after just starting Daminion. Regards, Volker Quote Link to comment Share on other sites More sharing options...
Volker Posted July 21, 2013 Author Report Share Posted July 21, 2013 With build 860 the behaviour is still unchanged. Regards, Volker Quote Link to comment Share on other sites More sharing options...
Volker Posted July 29, 2013 Author Report Share Posted July 29, 2013 Also with build 870 the described error occurs. Regards, Volker Quote Link to comment Share on other sites More sharing options...
Volker Posted August 10, 2013 Author Report Share Posted August 10, 2013 Build 875: error still exists. Is there any workaround to add a new place in the correct position? Volker Quote Link to comment Share on other sites More sharing options...
Volker Posted August 13, 2013 Author Report Share Posted August 13, 2013 With build 875 I now created a new catalog and imported all my pictures. Then after creation a new tag under 'Deutschland' I again have two trees named 'Country'. Is there any chance to get a response on this issue? Regards, Volker Quote Link to comment Share on other sites More sharing options...
