Uwe Posted December 14, 2024 Report Share Posted December 14, 2024 Hello, existing groups are not recognized and the result is: CTRL-T doesn't work. Regards, Uwe Quote Link to comment Share on other sites More sharing options...
Daria Kotilainen Posted December 16, 2024 Report Share Posted December 16, 2024 Hi Uwe, I was able to reproduce that, Oleg will be working on testing that as well. @Oleg.Rosslet us know your progress Quote Link to comment Share on other sites More sharing options...
lintujuh Posted December 18, 2024 Report Share Posted December 18, 2024 I will then postpone my update to 10.0, as I'm using groups very much. Quote Link to comment Share on other sites More sharing options...
lintujuh Posted December 27, 2024 Report Share Posted December 27, 2024 I was able to group two images and expand the group once immediately after the grouping. When I refreshed the main window which collapsed the group, I was no longer able to expand the group. Also, when I tried to do "Split group", nothing happened. And I have defined isSupportItemsGroup="true". Quote Link to comment Share on other sites More sharing options...
Daria Kotilainen Posted December 27, 2024 Report Share Posted December 27, 2024 Hi Juha, this is a known issue, we are working on it Quote Link to comment Share on other sites More sharing options...
lintujuh Posted February 19, 2025 Report Share Posted February 19, 2025 Hi! Any updates on this one? Quote Link to comment Share on other sites More sharing options...
Uwe Posted February 19, 2025 Author Report Share Posted February 19, 2025 working in build 3668 but you has to set the "true" option in the config file Quote Link to comment Share on other sites More sharing options...
Daria Kotilainen Posted February 19, 2025 Report Share Posted February 19, 2025 Hi Juha, yes, fixed in the lastet build: https://daminion.net/files/DaminionServerSetup-10.0.zip This functionality is now regulated by the config parameter: isSupportItemsGroup="true" Please edit the config file (setting is to be applied to each catalog), restart the server, and the groups will be available Quote Link to comment Share on other sites More sharing options...
lintujuh Posted February 19, 2025 Report Share Posted February 19, 2025 Thank you! Tested and works. Quote Link to comment Share on other sites More sharing options...
