phidias81 Posted March 15, 2015 Report Share Posted March 15, 2015 When I'm selecting my photos, in some folders I have Raw and automatic jpeg from the camera. If I cancel the raw, the jpeg is still there and viceversa. Is there a way to automatically link and delete the two? Best would be with a window asking for confirmation, maybe in the same windows asking to move the file to the recycle bin, it would be nice to have the possibility to check also to move the "twin" file. Otherwise I have to manually select later all the files missing the "twin", quite a tedious work. Davide Quote Link to comment Share on other sites More sharing options...
Murat Posted March 17, 2015 Report Share Posted March 17, 2015 We didn't decide yet, what approach to select to manage RAW+JPEG. Possible ways are: - Don't import JPEGs with a corresponding RAW images (fastest way to develop) - Group RAW and JPEG (it's not obvious whether this is a good approach) - Create a new "Versions" options to manage different versions of the same asset (slowest way to develop) Quote Link to comment Share on other sites More sharing options...
lintujuh Posted March 18, 2015 Report Share Posted March 18, 2015 Hi! Some raw editors embed the processing "recipe" in the raw file itself others create a separate sidecar file (e.g. .pp3 for RawTherapee). The most valuable files to have in an asset management system are the originals and the receipes, the final JPGs you can always recreate, if you have the sources. For using the digital assets it is valuable to have the final products available, unless Daminion could "seamless" launch the generation process and recreate the JPGs every time they are needed. I vote for the last option, as I have already described my ideal solution a year ago. As an intermediate solution I think the second one would be find, maybe added with a preference to create groups or not. -Juha Quote Link to comment Share on other sites More sharing options...
rene Posted March 28, 2015 Report Share Posted March 28, 2015 I like the idea of the function. You can use the function that is requested for panoramic and hdr images to group source and result files Quote Link to comment Share on other sites More sharing options...
