rene Posted January 5, 2014 Report Share Posted January 5, 2014 Hey folks, can I somehow let Daminion show me all place tags, that have no attached images? would be great to delete them thanks! René! Quote Link to comment Share on other sites More sharing options...
Uwe Posted January 6, 2014 Report Share Posted January 6, 2014 He Rene, what do you mean with "empty"? You see in the Ctalog Tags all Places Tags and the number of assigned items. To see the sub-tags you have to explode the Palces Tags - but you know that. Regards, Uwe Quote Link to comment Share on other sites More sharing options...
Mammut Posted January 6, 2014 Report Share Posted January 6, 2014 He Rene, what do you mean with "empty"? You see in the Ctalog Tags all Places Tags and the number of assigned items. To see the sub-tags you have to explode the Palces Tags - but you know that. Regards, Uwe I guess it's a little too long list if you added a lot of tags previously. If you delete the images, the tags are remaining there (which is a good thing, i need the already created tag structure), so there can be a lot of tags with zero assigned item, it can be a lot of time to find them all manually. Quote Link to comment Share on other sites More sharing options...
rene Posted January 7, 2014 Author Report Share Posted January 7, 2014 I know, but at some point I somehow assigned a new tag, and ended up with a lot of empty ones. I can't use them since I use them only for pictures and videos, so when they are not assigned they can go Quote Link to comment Share on other sites More sharing options...
deanable Posted January 13, 2014 Report Share Posted January 13, 2014 Hi Rene In my understanding just below the "Places" group there is a set of tags in Square Brackets This is the unassigned or empty tags. You can also use the advanced search to build your search for empty tags. I am not sure if this search works correctly because the status panel lists incorrect categories. See below when I search by selecting empty tags for Country AND State AND City AND Location the panel reports Country AND Country AND Country AND Country? Quote Link to comment Share on other sites More sharing options...
