Uwe Posted December 6, 2013 Report Share Posted December 6, 2013 Hello, it seems, that Daminion doesn't write the full time information from the import source file in the destination file when the seconds value of the source file is "00". I got the information in Geosetter that some files (DNG and JPG) don't have the date/time information when the photo was taken. In Daminion the Creation DateTime (e.g. 5 December 2013 14:30:00) for both files seems to be ok. But in the Metadata the "DateTime Original" and "Create Date" have these values: Date/Time Original 2013:12:05 14:34: Create Date 2013:12:05 14:34: The seconds are missing. That leads to the error message in Geosetter. The original source CR2 and JPG files have the full time information: Date/Time Original 2013:12:05 14:34:00 Create Date 2013:12:05 14:34:00 There seems to be a bug in the time tranformation of the import process. I changed the time in the Properties Window for the DNG and the JPG items to 14:34:01 -> this information is in the matadata of both files now. Then I changed the time information back to 14:34:00 -> the time metadata of the DNG file is ok now: 14:34:00. But in the JPG the time metadata is wrong again: 14:34: I'll send example files (original and renamed by Daminion, and a video) to you by email. Regards, Uwe Quote Link to comment Share on other sites More sharing options...
Murat Posted December 12, 2013 Report Share Posted December 12, 2013 Fixed. Quote Link to comment Share on other sites More sharing options...
Uwe Posted December 15, 2013 Author Report Share Posted December 15, 2013 Hi Murat, the tag Create Date is still wrong. The DateTime Original is ok. Regards, Uwe Quote Link to comment Share on other sites More sharing options...
Uwe Posted April 3, 2014 Author Report Share Posted April 3, 2014 Hello, this bug is back. The second information of DateTimeOriginal is missing in the DNG file when the seconds value in the source file is "00". See explanation above in the initial post. Create Date is ok. See screenshot please. I've scanned a little bit more my files and have this problem with other media formats of images too (TIF, JPG). Tested with shared catalog. I didn't want to open a new post. Regards, Uwe Quote Link to comment Share on other sites More sharing options...
Murat Posted April 3, 2014 Report Share Posted April 3, 2014 I can't reproduce this issue. Can you please record me a short video with the following steps: - Set some date to an image with 00 seconds - Actions > Write Tags To Images - Actions > Show All Metadata And please show me also the "Preferences > Writing Metadate" window Quote Link to comment Share on other sites More sharing options...
Uwe Posted April 3, 2014 Author Report Share Posted April 3, 2014 Hi Murat, it works, when I set the seconds in the Properties Panel but not when it is imported and converted from CR2 to DNG. I'll send a video by email to you. Regards, Uwe Quote Link to comment Share on other sites More sharing options...
Arne-Jaeger Posted September 28, 2014 Report Share Posted September 28, 2014 Hi, I have the same problem. I do a lot of importing, tagging and reimporting at the moment. It seems to me the error occurs in when importing. The seconds in DateTimeOriginal are empty, when they should be '00'. Sometimes even CreateDate is affected. Cheers Arne. Quote Link to comment Share on other sites More sharing options...
fhahn Posted October 5, 2014 Report Share Posted October 5, 2014 I posted a topic on this a few days ago because I did not see this thread. I was thinking it just affected my TIFF files but after seeing this, I started looking for JPG files that might be affected and it looks like I have a lot of them that have the seconds truncated in the DateTimeOriginal and CreateDate fields. I spent yesterday trying to fix all of the TIFF files that have been affected. Right now, I don't know how many JPG files are affected or how long it may take to fix this. Frank Hahn Quote Link to comment Share on other sites More sharing options...
fhahn Posted April 30, 2015 Report Share Posted April 30, 2015 This is still an issue. I am using Daminion version 3.7 (1187). Like has been mentioned earlier, any files that have time ending in :00 gets truncated after Daminion modifies the file. The metadata fields that I see get truncated are DateTimeOriginal and CreateDate. One thing I have noticed is that as long as Exif:ModifyDate has a time stamp, you can't add back the ending seconds (00). Once this field is empty, you can. The software that I use to look at and modify these fields is ExifToolGui. It is a front end to exiftool. I keep exiftool updated and I see the same results after Daminion modifies a file. Thanks. Frank Hahn Quote Link to comment Share on other sites More sharing options...
