823 - camera lens not correct
Volker
as far as I understand the priority to read the tags it should be this one as described in the document:
1. XMP:AUX:Lens,
2. EXIF:MakerNote:Lens,
3. EXIF:Lens
Is there an old release, an error in the documentation or am I wrong? I can't find the tag EXIF:MakerNote:Lens.
In may case (DNG-file) it should be read from EXIF:AUX:Lens.
No problems so far - tested with 825 build.
I scanned my shared catalog and found 3 JPG items with camera lens tag: "-7-2mm f/3.5-5.6". All photos where taken by a Nikon D5000 and the Exif:MakerNotes:Lens = 18-105mm f/3.5-5.6.
But, and this is maybe important, there are also 3 DNG items in the catalog with the same Creation DateTime made by a Canon 5D, Lens = 70-200mm.
Is it possible that the trouble comes from these 3 pairs of items with the same time stamp? The pattern of the focal length point to this assumption.
I just upgraded to build 826 - the behaviour did not change.
I see the following info using the 826 build with your images:
Could you please select these images again and invoke "Item > Actions > Read Tags from File" command to re-read metadata from images.
