kalain Posted July 27, 2012 Report Posted July 27, 2012 Hi, Dimension and size infos are not correctly displayed in Full screen window. Try this : - Open Daminion - Expand Keyword list in Catalog Tag window - Select a keyword with several images Now, in these few selected thumbnail, double click on first thumbnail. Dimension and size info is well displayed for first image but not for the second (up to the last image) Now, quit full screen mode. Double click on first thumbnail now Dimension and size infos are correctly displayed up to last image !!! Regards Quote
Uwe Posted July 27, 2012 Report Posted July 27, 2012 Hi, is it the same as decribed in the topic "missing file and photo size in full sreen window" in this forum for version 583? Regards, Uwe Quote
kalain Posted July 27, 2012 Author Report Posted July 27, 2012 Yes, seems to be the same problem. What's strange here, the first time you display in Full screen it doesn't work (doesn't display correctly all informations), the second time you display in full screen it seems to work properly !!! Quote
Murat Posted July 27, 2012 Report Posted July 27, 2012 Does the problem is reproducible with a newly created catalog? Quote
kalain Posted July 27, 2012 Author Report Posted July 27, 2012 Does the problem is reproducible with a newly created catalog? Yep, this problem is here with a newly created catalog and 6 images imported. First time, only first image infos are corect. Second time, all images infos are ok. Will post later a longer answer. Quote
Uwe Posted July 27, 2012 Report Posted July 27, 2012 Hello, I can't reproduce it with a new shared catalog in version 591). Regards, Uwe Quote
