rene Posted September 25, 2022 Report Share Posted September 25, 2022 Dear fellow Daminion user, in order to get the Face Recognition done faster and more accurate, I requested Facial Recognition for certain folders, until this will be available, I was thinking of a workaround. Would it work, if I create a NEW Catalog and only attach one folder or, e.g. the folders from my mother's side of the family and then sit down with that part of the family to assign the people to the photos and then import them into the main catalog? Will the faces aka person be imported? The big pro would be, to have less server load, server can scan only the 5000 photos in those folders instead of 200000 photos in main catalog and I can more accurately assign faces because I know which persons might show up and who might not. thanks Quote Link to comment Share on other sites More sharing options...
Daria Kotilainen Posted September 26, 2022 Report Share Posted September 26, 2022 Hi Rene, Unfortunately, this approach may not work properly - you would need to import the files, then copy the midsize preview folder, thumbnail folder and faces previews folder and merge it with the original catalog. However, I have not tested this approach myself. @Oleg.Rosswill this approach work or would you advice against it? Kind regards, Daria Quote Link to comment Share on other sites More sharing options...
rene Posted September 28, 2022 Author Report Share Posted September 28, 2022 Hey Daria, I just wanted to get the face regocnition done but scanning over 200000 files and assigning faces even brings my 16gb ram server to it's limits Quote Link to comment Share on other sites More sharing options...
Daria Kotilainen Posted September 28, 2022 Report Share Posted September 28, 2022 Hi Rene, please try activating FR overnight and stop when you are doing other tasks during the day. What's your current Daminion version btw? Daria Quote Link to comment Share on other sites More sharing options...
rene Posted September 28, 2022 Author Report Share Posted September 28, 2022 Hey Daria, i run the latest Daminion Quote Link to comment Share on other sites More sharing options...
