rene Posted June 11, 2021 Report Share Posted June 11, 2021 Hello community, today I noted, that there is an issue with DaminionServer Daminion Server is not starting File Watching and SQL runs restarting the computer doesn't change it We didn't change anything on the machine! It used to run! Thank you Quote Link to comment Share on other sites More sharing options...
SergeS Posted June 11, 2021 Report Share Posted June 11, 2021 5 hours ago, rene said: Hello community, today I noted, that there is an issue with DaminionServer Daminion Server is not starting File Watching and SQL runs restarting the computer doesn't change it We didn't change anything on the machine! It used to run! Thank you Did service start? On older (very old) versions I see sometimes service did not start automatically. Quote Link to comment Share on other sites More sharing options...
rene Posted June 13, 2021 Author Report Share Posted June 13, 2021 no it didn't tried it today as well! same issue should it run as localaccount or a specific user? Quote Link to comment Share on other sites More sharing options...
Daria Kotilainen Posted June 15, 2021 Report Share Posted June 15, 2021 Hi Rene, Can you please go to Windows services and check the user that runs Daminion file watching service? Can you please try to start it from there and if you get any message oor it simply takes long to start, please check your Event Viewer and let me know the error message Daria Quote Link to comment Share on other sites More sharing options...
rene Posted September 26, 2021 Author Report Share Posted September 26, 2021 got the same issue now with the latest builds Quote Link to comment Share on other sites More sharing options...
Daria Kotilainen Posted September 27, 2021 Report Share Posted September 27, 2021 Hi Rene, when you install the new build, please make sure to install it under the same user that was used to run the previous build. We can schedule a remote session, please drop me a msg by Whatsapp Daria Quote Link to comment Share on other sites More sharing options...
