Len Posted January 17, 2021 Report Share Posted January 17, 2021 Win 10 version 20H2 Daminion Standalone 6.8.0 After extensive help from Daria, much appreciated, I cannot in Daminion display Canon or Olympus Raw files. Only blank squares where they should be? along with full file details just not the Image. All other Photo Software, ACDsee, Zoner, PHOTOworks, etc displays RAW files OK. By right clicking the thumbnail and opening in Editing Software it opens OK. If it had previous MetaData applied these show up in right hand panel. I have updated the GPU driver graphics also but the problem still it exists? Can anyone offer a solution please? Quote Link to comment Share on other sites More sharing options...
FlyNBike Posted January 22, 2021 Report Share Posted January 22, 2021 I installed Raw Image Extension from Microsoft Store, Canon CR3 files now display thumbnails and metadata OK. Previews are a bit small and don't zoom well, but I can live with that Quote Link to comment Share on other sites More sharing options...
Len Posted February 8, 2021 Author Report Share Posted February 8, 2021 On 1/22/2021 at 5:05 PM, FlyNBike said: I installed Raw Image Extension from Microsoft Store, Canon CR3 files now display thumbnails and metadata OK. Previews are a bit small and don't zoom well, but I can live with that Hi FlyNBike, this seems to be just a programme that uploads CR* File to the Computer!! I have no problem uploading , it`s just Daminion that does not display Raw Files, all other Software sees them OK. Quote Link to comment Share on other sites More sharing options...
rene Posted February 22, 2021 Report Share Posted February 22, 2021 cr2 are loaded on my server but ORF files are still unsupportet Quote Link to comment Share on other sites More sharing options...
lintujuh Posted February 23, 2021 Report Share Posted February 23, 2021 Do you have the problem when importing the ORFs or is the problem also when you have the ORFs in your catalogue? I don't see the previews when importing the images, but when the images are imported they are visible in Daminion. Quote Link to comment Share on other sites More sharing options...
