Volker Posted December 21, 2020 Report Share Posted December 21, 2020 When trying to search an image in 6.8.0 I get this error message. Quote Link to comment Share on other sites More sharing options...
Katerina Karpenko Posted December 21, 2020 Report Share Posted December 21, 2020 Hello, Could you please give us more details 1. Are your working with local or shared catalog? 2. What version of Daminion did you update from? Regards, Kate Quote Link to comment Share on other sites More sharing options...
Volker Posted December 21, 2020 Author Report Share Posted December 21, 2020 Hello Katerina, I am working with a shared catalog. Not sure about the previous version; I assume I came from 6.7.0.2245; are there any logs to look it up? Best regards, Volker Quote Link to comment Share on other sites More sharing options...
Katerina Karpenko Posted December 21, 2020 Report Share Posted December 21, 2020 Could you please send me your backup file? And 6.8.0.2333 version is available now. You can find it by the link https://daminion.net/download-server?showbuttons We'll update the version in "Help - Check for updates Online" soon. Quote Link to comment Share on other sites More sharing options...
WilfriedB Posted December 21, 2020 Report Share Posted December 21, 2020 2 hours ago, Volker said: Not sure about the previous version; I assume I came from 6.7.0.2245; are there any logs to look it up? Volker, one tip since I am also not a aware of any installation log: Even though, it is a lot of wasted disk space, I keep all the install files I downloaded. It not only provides information what your previous was, but also when installed it (assuming, you install on the same date, when you downloaded it). Also, if something goes wrong with the new version, which cannot be solved immediately, you can go back easily. In some cases, you also need to restore a backup of the catalog!. I did face a similar problem a while ago, but it was before 6.8 came out. Not sure anymore though, what exactly did fix the problem. Possibly it was only a restart of Windows. Quote Link to comment Share on other sites More sharing options...
