Len Posted October 2, 2020 Report Share Posted October 2, 2020 As the Title, since upping from Home to Server Base none of my RAW files will display, CR2 and ORF. Any suggestions, personally think it a Windows Problem, any Ideas? Quote Link to comment Share on other sites More sharing options...
Daria Kotilainen Posted October 2, 2020 Report Share Posted October 2, 2020 Hi Len, Can you please try to regenerate the thumbnails by selecting the files and clicking CTRL+ B? Please send me a sample files as well Kind regards Daria Quote Link to comment Share on other sites More sharing options...
l.miklos Posted October 5, 2020 Report Share Posted October 5, 2020 Hi Len, If you select a folder and press F6 (Rescan folder), there you can see a button "Import filter". By pressing it you can select, which media formats will be imported. Miklos Quote Link to comment Share on other sites More sharing options...
Len Posted October 5, 2020 Author Report Share Posted October 5, 2020 Hi, Daria Sorry not to well at the Moment but just tried your suggestion, no change i.miklos, also tried your suggestion, no change there either 20200922_130316_9220145.ORF Quote Link to comment Share on other sites More sharing options...
Daria Kotilainen Posted October 5, 2020 Report Share Posted October 5, 2020 Hi Len, In my case, the file is displayed Please let me know if the thumb regeneration will work Kind regards Daria Quote Link to comment Share on other sites More sharing options...
Len Posted October 6, 2020 Author Report Share Posted October 6, 2020 Hi Daria, CTRL+B makes no difference, tried to implement Rescan folder but made no difference either, no sure if I'm doing it correctly. The thing is I have a Number of Photo editors, Paid and Free and all CR" and ORF files display OK in all of these, so looks like a Daminion Problem Cheers Len Quote Link to comment Share on other sites More sharing options...
Daria Kotilainen Posted October 6, 2020 Report Share Posted October 6, 2020 Hi Len, I was checking your file on Daminion server, build 2237. Do you have the same build? We can also schedule a remote session to take a look at this issue Kind regards Daria Quote Link to comment Share on other sites More sharing options...
Len Posted October 7, 2020 Author Report Share Posted October 7, 2020 Remote Session seems to be the answer. Quote Link to comment Share on other sites More sharing options...
Daria Kotilainen Posted October 7, 2020 Report Share Posted October 7, 2020 Please contact me by email to take a look at the issue. Kind regards Daria Quote Link to comment Share on other sites More sharing options...
