2216 - GPX format not a unknown format
Uwe
well done: The GPX files are not assigned to "unknown format". The are displayed as GPX under the "Others".
One question: How is it possible to get all existing GPX files assigned to "Others->GPX" automatically?
At the moment I've tagged all my GPX files with the Keyword Tag "GPX" and would like to delete this tag now. The only way I see now is to export all GPX items into a CSV file, then remove the items from catalog and to reimport the files. The disadvantage is: the items get new "itemids" and all existing links of these items are gone.
Update: question:
items already assigned to the Media Format GPX are assigned to the the mediaformatui in the database:
the other still "unknown" GPX items are assigned to:
I would like to update the table and substitute the "old" entry by the "new" one. Is this ok?
Hello Kate,
thanks for the answer. Can you please give a short information what kind of problems can happen? I chanded one record manually by pgAdmin and everything was ok. No problems.
There are 779 GPX files to change in my database and export and import is not a solution for me because of this amount of items and the described problems above.
From my point of view: the only difference in the table "mediaitems" between the records are the columns "mediaformatui" (the unique identifier) and "id_mediaformat" (the link to the table "mediaformat_table" which is the pointer to the unique identifier).
 I did it. I made the update with pgAdmin. No risk - no fun 😉 The values are valid in my DB and can be other in other DBs
UPDATE mediaitems
    SET mediaformatui = '4ee1f8a8-023e-4126-b112-8f6f391f6966', id_mediaformat = 64
   WHERE name LIKE '%gpx'
   AND mediaformatui = '00000000-0000-0000-0000-000000000000'
   AND deleted = false
   AND id_mediaformat = 38
I hope I do not have a typo in here now. I wrote it down from memory here.
regards, Uwe
