deanable Posted April 26, 2012 Report Posted April 26, 2012 Hi guys Please look at the recording attached here... Advanced Search Panel Control placement and anchoring.mov Note the operators and operands. between some operands the operators do not display and in the first set it does not even display at all. This is a minor GUI layout that can be tweaked when designing the form, I am sure? Also note the info panel above the results reports the selected tags as [Country] OR [Country] OR [Country] OR [Country]... Thanks for fixing the sync issue I had last night. SBTW I love the new import panel. This is a big step in the right direction !!!! Quote
Uwe Posted April 26, 2012 Report Posted April 26, 2012 Hi Dean, where did you find the version 530? Regards, Uwe Quote
deanable Posted April 26, 2012 Author Report Posted April 26, 2012 Hi Dean, where did you find the version 530? Regards, Uwe I sent you a PM with the download links.... Quote
Murat Posted April 27, 2012 Report Posted April 27, 2012 Thank you Dean, the problem with operands will be fixed. Quote
