WilfriedB Posted February 16, 2020 Author Report Share Posted February 16, 2020 11 hours ago, k1w said: Bumping this to see if there's been any progress made the issues with AI labels -- searching for empty, recovering deleted AI labels, etc.? Same here. I am still on Build 2033 and not aware of any newer test build approaching this issue. Quote Link to comment Share on other sites More sharing options...
Daria Kotilainen Posted February 17, 2020 Report Share Posted February 17, 2020 Hi guys, the build 2067 will be available on the forum soon. As far as I know, my colleagues have addressed some AI labels issues. However, the deleted AI labels cannot be recovered, only regenerated. Kind regards Daria Quote Link to comment Share on other sites More sharing options...
k1w Posted February 17, 2020 Report Share Posted February 17, 2020 Wonderful to hear, Daria! Thanks for the update. Will it handle being able to search for photos with empty tags, and thus also adding tags only to those that have not yet been processed? If you delete all tags from a photo, does that get considered as "empty" (untagged) and thus would be requested again if you attempt to generate tags for unprocessed files, or will it be treated as "no tags" (tags were generated, discarded as unwanted, so not processed again)? Or will the user have the ability to specify either state per photo? Looking forward to trying it out! Quote Link to comment Share on other sites More sharing options...
WilfriedB Posted February 17, 2020 Author Report Share Posted February 17, 2020 1 hour ago, Daria Kotilainen said: the deleted AI labels cannot be recovered, only regenerated. Fair enough! Quote Link to comment Share on other sites More sharing options...
Daria Kotilainen Posted February 20, 2020 Report Share Posted February 20, 2020 Hi guys, Quote If you delete all tags from a photo, does that get considered as "empty" (untagged) and thus would be requested again if you attempt to generate tags for unprocessed files, or will it be treated as "no tags" (tags were generated, discarded as unwanted, so not processed again)? Or will the user have the ability to specify either state per photo? yes, the file will be treated as empty and places under Unassigned if you remove all AI labels. I'm testing a new build, 2067, but, unfortunately, still noticing some inconsistency. Let me talk tomorrow to my colleagues to clarify when the stable build with this issue fixed will be out. Kind regards, Daria Quote Link to comment Share on other sites More sharing options...
Daria Kotilainen Posted March 12, 2020 Report Share Posted March 12, 2020 The issue has been fixed in the new version - please test it out. Please remember to check if your Free updates period is active before the upgrade. Kind regards Daria Quote Link to comment Share on other sites More sharing options...
WilfriedB Posted March 13, 2020 Author Report Share Posted March 13, 2020 As far as I can see, it is working correctly after installing Build 2086 and 2089 👍. Quote Link to comment Share on other sites More sharing options...
k1w Posted March 16, 2020 Report Share Posted March 16, 2020 Appears to be working for me as well. Thank you! Quote Link to comment Share on other sites More sharing options...
