WilfriedB Posted July 29, 2019 Report Share Posted July 29, 2019 During the Installation of Build 1960, I received an error message that CVis.exe could not be replace. It worked fine, after I killed that task with Windows Task Manager Quote Link to comment Share on other sites More sharing options...
rene Posted July 30, 2019 Report Share Posted July 30, 2019 I didn't got that Error Message, but another one. JUst forgot to save a screenshot Quote Link to comment Share on other sites More sharing options...
Daria Kotilainen Posted July 30, 2019 Report Share Posted July 30, 2019 Hi Wilfried, registered, thank you for reporting Daria Quote Link to comment Share on other sites More sharing options...
WilfriedB Posted July 30, 2019 Author Report Share Posted July 30, 2019 You're welcome, Daria 😊 Only recently, I noticed CVis.exe being active consuming CPU once in a while. Is it part of new function? Quote Link to comment Share on other sites More sharing options...
Daria Kotilainen Posted July 30, 2019 Report Share Posted July 30, 2019 yes, if you are generating new AI labels 🙂 Quote Link to comment Share on other sites More sharing options...
WilfriedB Posted July 30, 2019 Author Report Share Posted July 30, 2019 Ah ok. I did indeed activate, but it never worked for me. I reported it in another post. Quote Link to comment Share on other sites More sharing options...
Daria Kotilainen Posted July 30, 2019 Report Share Posted July 30, 2019 mmm Wilfried where are you looking for the generated labels? the thing is, I thought it was not working for me either and then found out the labels are not put under Keywords but under AI labels tag 😄 was not very obvious for me Quote Link to comment Share on other sites More sharing options...
WilfriedB Posted July 30, 2019 Author Report Share Posted July 30, 2019 Yes, I did watch there. I am able to enable AI Labels, add the Google Vision key and restart the server, but when I select Actions -> Generate AI Labels, nothing happens, not even an error message. I posted a while ago, but didn't try again recently: Quote Link to comment Share on other sites More sharing options...
WilfriedB Posted July 30, 2019 Author Report Share Posted July 30, 2019 Correction: I just watched again under AI Labels and found 1977 items, but all under the label "Unknown". So something did happen. The 1,977 items seem to be quite arbitrarily collected. Some, but by far not all of the most recently imported and many very old items (imported last year and created in the year 1999) Quote Link to comment Share on other sites More sharing options...
Daria Kotilainen Posted July 30, 2019 Report Share Posted July 30, 2019 Wilfried, can you please send me your json file? I will test it out Daria Quote Link to comment Share on other sites More sharing options...
WilfriedB Posted July 30, 2019 Author Report Share Posted July 30, 2019 OK, I sent it via mail. Could it be possible, it is an extremely slow process, depending on the size of the catalog (my catalog has 187,000+ items) and it reports all "unknown" first" Quote Link to comment Share on other sites More sharing options...
Mr.B Posted December 19, 2019 Report Share Posted December 19, 2019 I just got this too with Server 6.3. Have followed your @WilfriedB advice and all installed fine. 🙂 Quote Link to comment Share on other sites More sharing options...
Daria Kotilainen Posted December 20, 2019 Report Share Posted December 20, 2019 Hi guys, sorry about the CVis.exe issue - it will be fixed soon Daria Quote Link to comment Share on other sites More sharing options...
