kingsfan Posted June 7, 2011 Report Share Posted June 7, 2011 I do not see an option to view GPS information embedded in EXIF, either in CR2 or ORF files. Is this funtionality to be expected soon? By the way, this is the only software I found that respects IPTCEXT:personinimage tag. Thanks. 1 Quote Link to comment Share on other sites More sharing options...
Murat Posted June 7, 2011 Report Share Posted June 7, 2011 Welcome to our community! Yes. We plan to add GPS information to Daminion Tags. -- Regards, Murat Quote Link to comment Share on other sites More sharing options...
kingsfan Posted June 7, 2011 Author Report Share Posted June 7, 2011 Thanks for the quick response. Can I look forward to testing this capability in the next beta release? ;) Quote Link to comment Share on other sites More sharing options...
Murat Posted June 7, 2011 Report Share Posted June 7, 2011 We have not decided yet what is the best way to represent the GPS info: - Just show GPS info in Properties pane as text fields (not informative) - Embed Google Maps and display markers on the map... - Embed Bing... The first way could be implemented easily but I guess it's not the best way to see the GPS info. Quote Link to comment Share on other sites More sharing options...
kingsfan Posted June 7, 2011 Author Report Share Posted June 7, 2011 My suggestion would be to start by exposing the GPS data as EXIF property Text Fields in the initial release. Later you can incorprate the mapping functionality.That is, do the easy stuff first :-). The field can be read-only as well for now. I use Expression Media 2 today and it incorporates into Bing; however I hardly use that functionality. What I like to see however is the the GPS data I have added to my photos by syncing with GPX track logs (currently using Geosetter) actually shows up as an EXIF tag. Think of the functionality as a tool to confirm that all EXIF properties (or at least the ones I have manually embedded) are viewable via a Cataloging software. Without a way to view this property as I can in Expression Media 2 today, Daminion will have a gap that could easily have been filled, so I really hope you add at least the Text Fields for now. Thanks for your consideration . Quote Link to comment Share on other sites More sharing options...
Murat Posted June 7, 2011 Report Share Posted June 7, 2011 Text GPS fields might be incorporated soon. Just in case, our RoboImport software is also can populate GPS info GPX track logs. Quote Link to comment Share on other sites More sharing options...
kingsfan Posted June 9, 2011 Author Report Share Posted June 9, 2011 There are programs like IDImager which (as far as I can tell) ignore EXIF GPS data and look for GPS data in XMP only by default. I hope you will be displaying GPS data available as EXIF tags and not always look for GPS data in XMP-EXIF tags. Thanks in advanced if you are planning on respecting and displaying the EXIF GPS tags as embedded in RAW and JPG files. Quote Link to comment Share on other sites More sharing options...
Murat Posted June 9, 2011 Report Share Posted June 9, 2011 We follow MWG specification here. And you are right: MWG Specification4.2.3.1 Handling Exif and XMP If a file has Exif and XMP blocks the application shoul read both XMP and Exif but prefer Exif. Just in case if you need to copy all of your GPS info from XMP to EXIF you can use ExifTool by Phil Harvey (you can locate in on the Daminion folder also) Example of the usage: exiftool "-gps:all Quote Link to comment Share on other sites More sharing options...
kingsfan Posted June 25, 2011 Author Report Share Posted June 25, 2011 Thanks for adding GPS information to the Properties in the latest (337) build. Much appreciated. Please take a look at the formating though. The Lat and Long reference is not correct. For example a West designation is being shown as a South designation. It will also be nice to see the option for altitude to be shown in "feet" instead of "meters". Quote Link to comment Share on other sites More sharing options...
Murat Posted June 27, 2011 Report Share Posted June 27, 2011 Fixed. Thanks for the note! I hope we'll release a minor Daminion 0.8.3 update today. The altitude will be shown as: 111 m (364.17 ft) Quote Link to comment Share on other sites More sharing options...
kingsfan Posted June 28, 2011 Author Report Share Posted June 28, 2011 Fixed. Thanks for the note! I hope we'll release a minor Daminion 0.8.3 update today. The altitude will be shown as: 111 m (364.17 ft) I do not believe this to be fixed in Build 340. See the attached screen caps. Capture.JPG is the GPS reported by EXIFTOOLGUI, and Capture1.JPG is the GPS reported by Daminion. The coordinates and compass direction (N,E,W,S) are still wrong. Quote Link to comment Share on other sites More sharing options...
Murat Posted June 28, 2011 Report Share Posted June 28, 2011 Could you please send me that photo to support at daminion dot net. Quote Link to comment Share on other sites More sharing options...
Murat Posted June 28, 2011 Report Share Posted June 28, 2011 Fixed. Quote Link to comment Share on other sites More sharing options...
kingsfan Posted June 28, 2011 Author Report Share Posted June 28, 2011 Do you still need the photo? Quote Link to comment Share on other sites More sharing options...
Murat Posted June 28, 2011 Report Share Posted June 28, 2011 I've emailed you a link to the new Daminion build. Could you please check it. If the problem still there, please send me that photo. Quote Link to comment Share on other sites More sharing options...
kingsfan Posted June 28, 2011 Author Report Share Posted June 28, 2011 Problem is fixed in the latest build you have emailed to me. Thanks. Quote Link to comment Share on other sites More sharing options...
kalain Posted November 18, 2012 Report Share Posted November 18, 2012 My suggestion would be to start by exposing the GPS data as EXIF property Text Fields in the initial release. Later you can incorprate the mapping functionality.That is, do the easy stuff first :-). The field can be read-only as well for now. Following this old discussion, now you can see and display Lat/Long but how can I use Daminion to map selected pictures ? I expected to : - search and find some pictures with Daminion, - put selection in Tray, - select all images in Tray and make a geo setting file like a kmz file in order to display them with Google Earth. I didn't find a way to export a geo tag file in order to display my image Daminion selection in a map. Any advice (even without Daminion) ? Thanks. Quote Link to comment Share on other sites More sharing options...
kingsfan Posted November 19, 2012 Author Report Share Posted November 19, 2012 GeoSetter has an option to export images to Google Earth - in case that helps. You can also use ExifTool (http://www.sno.phy.queensu.ca/~phil/exiftool/geotag.html#Reverse) Quote Link to comment Share on other sites More sharing options...
kalain Posted November 19, 2012 Report Share Posted November 19, 2012 GeoSetter has an option to export images to Google Earth - in case that helps. You can also use ExifTool (http://www.sno.phy.queensu.ca/~phil/exiftool/geotag.html#Reverse) Thanks for your answer. GeoSetter is exactly what I was looking for. (create a kmz file from image selection) It would be nice if under Daminion you could create a kmz file from selected images or from Tray images. Yes, this would be very cool to do this from your favorite DAM software. Regards Quote Link to comment Share on other sites More sharing options...
Murat Posted November 19, 2012 Report Share Posted November 19, 2012 Thanks for the suggestions! Displaying selected images in a map is existed in our feature list. Quote Link to comment Share on other sites More sharing options...
kalain Posted November 19, 2012 Report Share Posted November 19, 2012 Thanks for the suggestions! Displaying selected images in a map is existed in our feature list. mmmh, I think there is two targets here. 1/ Displaying selected images in a map is one thing. 2/ Create a kmz file from selected images is another thing. because with this kmz file you will be able to display it with google earth or any other map software which accept kmz file and use it's tools like distance measurements and so on. (which I guess will not be available under Daminion.) So, please do not forget "create kmz file" function from selected images which I think will require less work than to display images in internal Daminion maps. Regards Quote Link to comment Share on other sites More sharing options...
Mardon Posted February 26, 2013 Report Share Posted February 26, 2013 Just in case if you need to copy all of your GPS info from XMP to EXIF you can use ExifTool by Phil Harvey (you can locate in on the Daminion folder also) Example of the usage: exiftool "-gps:all<all" "-gpsdatestamp<gpsdatetime" "-gpstimestamp<gpsdatetime" ... For any command-line averse people who are interested in geotagging images that are not tagged by your camera, Geotag (http://geotag.sourceforge.net) is great. It requires ExifTool (http://www.sno.phy.q...~phil/exiftool/) mentioned above by Murat. And the ExifToolGUI(http://u88.n24.queensu.ca/~bogdan/) is a great GUI front-end for the Windows version of ExifTool. As of v0.9.9 (731) Daminion reads geotags from image files but there is not currently any way to add them manually from within Daminion. I'm using Geotag to do this. Quote Link to comment Share on other sites More sharing options...
kalain Posted February 26, 2013 Report Share Posted February 26, 2013 As of v0.9.9 (731) Daminion reads geotags from image files but there is not currently any way to add them manually from within Daminion. I'm using Geotag to do this. Thanks for this info. This topic/request join this one : https://daminion.net/user-forum/index.php?/topic/582-lat-long-altitude Yes, Lat & Long should be editable but not so easy to implement this in the software because this open a big door and possible troubles... Quote Link to comment Share on other sites More sharing options...
Murat Posted February 26, 2013 Report Share Posted February 26, 2013 An ability to geo-tag photos will be added on the next Daminion minor update. Quote Link to comment Share on other sites More sharing options...
Mardon Posted February 26, 2013 Report Share Posted February 26, 2013 An ability to geo-tag photos will be added on the next Daminion minor update. Great! How many geo-tags will be included? I guess the main ones are Latitude, Longitude, Altitude and Datum. Will all four of these be available? Any other geo-tags? Quote Link to comment Share on other sites More sharing options...
