lorenz Posted February 12, 2017 Report Share Posted February 12, 2017 Hi all, I have a strange problem: when Daminion Server is running, my smartphone (which is in the same network as the computer where Daminion is installed) is constantly receiving something. The litte download arrow under the network icon is constantly there. This prevents the phone from going into deep sleep and the battery is empty after a few hours (normally after 2 days). If I switch of the Daminion Server the download arrow disappears instantly and everything is fine! As I use Daminion Server only on the computer where it is installed (I need the Server version only for its speed), I tried to set up the firewall to block Daminion but it didn't help. Or I didn't do it right. Has anybody else experienced this behaviour and has a solutino for it? Best Lorenz Quote Link to comment Share on other sites More sharing options...
rene Posted February 13, 2017 Report Share Posted February 13, 2017 Hello Lorenz, I never heard about that issue before. Let's see if other people are reporting this as well Quote Link to comment Share on other sites More sharing options...
lorenz Posted February 15, 2017 Author Report Share Posted February 15, 2017 Hello Lorenz, I never heard about that issue before. Let's see if other people are reporting this as well Hi, I could finally solve it by blocking Daminion Server by the firewall. Maybe there is a misconfiguration? The firewall is blocking every second 100+ connections!? Remote address: 255.255.255.255 Aim port: 15253 Protocol: UDP Outgoing Does this say anything to anybody? Thank you!! 1 Quote Link to comment Share on other sites More sharing options...
Murat Posted May 7, 2019 Report Share Posted May 7, 2019 Lorenz, thanks for the post! Daminion Server sends broadcast packets so Daminion Clients could automatically find it without the necessity to register Daminion Server manually. You can disable this by editing daminion.config file:https://help.daminion.net/en/ I will register this issue (may be we will switch it off by default or change its behavior) Quote Link to comment Share on other sites More sharing options...
lorenz Posted May 21, 2019 Author Report Share Posted May 21, 2019 Thanks Murat! That's quite helpful, even two years after my post! 🙂 All the best Lorenz Quote Link to comment Share on other sites More sharing options...
Murat Posted May 24, 2019 Report Share Posted May 24, 2019 Hello Lorenz. Right :) It seems a spammer's post (that was deleted them) raised up this post and I thought that this was a new one. Anyway, we rewrote the code logic that is responsible for automatic recognition of installed Daminion Servers in the local network. It works much faster now (in the internal build now). Instead of constantly pushing small UDP packets by Daminion Server now, a newly opened Daminion Client will send a single UDP packet once. It will be catched by Daminion Server and Daminion Client will be informed about this server. Quote Link to comment Share on other sites More sharing options...
