bro999 Posted November 13, 2016 Report Share Posted November 13, 2016 Daminion Standalone (v. 4.6.0.1481) reports incorrect lens info from files exported in GIMP (v. 2.8.18) with default export setting. In the catalog, all files taken with "Canon EF 100-400mm f/4.5-5.6L IS II USM" would showing "Canon EF 28mm f/2.8" after they were exported from GIMP. I examined the EXIF data using EXIFTOOL and nothing showing EF 28mm. I hereby attach one of the files which was resized in GIMP for your investigaton. Thanks. Quote Link to comment Share on other sites More sharing options...
Daria Kotilainen Posted November 14, 2016 Report Share Posted November 14, 2016 Daminion Standalone (v. 4.6.0.1481) reports incorrect lens info from files exported in GIMP (v. 2.8.18) with default export setting. In the catalog, all files taken with "Canon EF 100-400mm f/4.5-5.6L IS II USM" would showing "Canon EF 28mm f/2.8" after they were exported from GIMP. I examined the EXIF data using EXIFTOOL and nothing showing EF 28mm. I hereby attach one of the files which was resized in GIMP for your investigaton. Thanks. hello Alex, the issue is fixed for Canon EOS 6D in the new Daminion version. thank you for reporting! Best regards, Daria Quote Link to comment Share on other sites More sharing options...
Uwe Posted November 15, 2016 Report Share Posted November 15, 2016 Hello, even in this case the fix can help but how to handle this case: The photos were taken by the Canon5DMKIII and the Sigma lens 150-600mm I guess, Daminion doesn't have a chance in any case to determine the right lens when each manufacturer writes its own metadata Regards, Uwe Quote Link to comment Share on other sites More sharing options...
bro999 Posted November 16, 2016 Author Report Share Posted November 16, 2016 Hi Daria, Thank you for your reply. When will the new version be available for download? Alex Quote Link to comment Share on other sites More sharing options...
Daria Kotilainen Posted November 17, 2016 Report Share Posted November 17, 2016 Hi Daria, Thank you for your reply. When will the new version be available for download? Alex Hello Alex, the new version for beta testing is available now by this link (Daminion 5.0.1529) Daria Quote Link to comment Share on other sites More sharing options...
bro999 Posted November 17, 2016 Author Report Share Posted November 17, 2016 Oh, I see. Thanks for your link. Alex Quote Link to comment Share on other sites More sharing options...
