Paul Barrett Posted October 1, 2016 Report Share Posted October 1, 2016 How do I dock the 2nd tag window next to 1st please? - Paul Quote Link to comment Share on other sites More sharing options...
Murat Posted October 1, 2016 Report Share Posted October 1, 2016 You can rearrange (dock) the tag panels by moving them via tag panel header. Quote Link to comment Share on other sites More sharing options...
Paul Barrett Posted October 1, 2016 Author Report Share Posted October 1, 2016 Hi Murat Yes, I can see that I can move the 2nd panel around, and resize it to match the first panel but it obscures the images window. No matter how much I try, I cannot seem to get it to dock. If I double click the header bar of the 1st tags panel it undocks but I do the same to the 2nd panel it just positions it half off screen What am I missing please? - Paul Quote Link to comment Share on other sites More sharing options...
Daria Kotilainen Posted October 3, 2016 Report Share Posted October 3, 2016 Hi Murat Yes, I can see that I can move the 2nd panel around, and resize it to match the first panel but it obscures the images window. No matter how much I try, I cannot seem to get it to dock. If I double click the header bar of the 1st tags panel it undocks but I do the same to the 2nd panel it just positions it half off screen What am I missing please? - Paul Hello Paul, here is an article about how to dock panels http://help.daminion.net/customizing-the-window-layout/ and please see the images attached. The easiest way to dock the 2nd tag panel is to double click on its header bar, the 2nd panel should be positioned next to the 1st one (as shown on the second screen shot). How does it work in your case? Could you please show me? Daria Quote Link to comment Share on other sites More sharing options...
Paul Barrett Posted October 3, 2016 Author Report Share Posted October 3, 2016 Thanks Daria I had not seen that article. But I get it now! - Paul Quote Link to comment Share on other sites More sharing options...
