myFotoDATA Posted September 29, 2016 Report Share Posted September 29, 2016 Hi from Austria I have used Studio Line PhotoClassic 4 till I found Your product! Now I want to transfer my pictures to Daminion. So I exported them in two files: the RAW Picture and the xmp File with the same name In the xmp File there are three custom tags - BEZEICHNUNG I, BEZEICHNUNG II and BEZEICHNUNG III - as StudioLine:var (about in the middle of the file, the long line! After the import to daminion I get all the Tags besides the mentioned BEZEICHNUNG I, II, III Do You see any chance to get this information into daminion? That would be great! Thank You! ... how can I upload the RAW picture and the xmp file? raw is too big, xmp is not allowed as xmp! I changed the extension to txt - so it worked IMG_0002.txt Quote Link to comment Share on other sites More sharing options...
Daria Kotilainen Posted September 29, 2016 Report Share Posted September 29, 2016 Hello lupus, the only way to import custom tags created in external application is via CSV file. This way, you can simply create custom tags in Daminion with the same name as in Studio Line and then map these custom fields. However, based on the surface search, it seems that Studio Line doesn't support CSV import? Daria Quote Link to comment Share on other sites More sharing options...
Jacal Posted September 30, 2016 Report Share Posted September 30, 2016 After adding custom xmp-daminion and xmp-studioline tags to ExifTool's configuration file, it should be easy to copy or move data between them. I think. Quote Link to comment Share on other sites More sharing options...
Daria Kotilainen Posted October 5, 2016 Report Share Posted October 5, 2016 After adding custom xmp-daminion and xmp-studioline tags to ExifTool's configuration file, it should be easy to copy or move data between them. I think. hello Jacal, if you have this configuration file and could share it, it would be very helpful. Daria Quote Link to comment Share on other sites More sharing options...
