[solved 1397] - 1360 - XMP for PDF doesn't work
Uwe
Uwe. Thanks for the PDF file. I was able to write tags into your test PDF file by 1375 build, and then import this PDF into another catalog and all tag were extracted properly.
However your PDF file contains 5 XMP blocks and Daminion (or Adobe XMP Toolkit) reads only one block.
Hi Murat,
I can't do it with build 1375. I used the same file, entered the title and description tag in the Properties Panel but they were not written to the file. I worked as "local system" on the laptop.
BTW, I can't decide how many XMP blocks will be written to the file by the different software. The best for me is: there is a XMP block owned by Daminion (XMP:Daminion) for all properties managed by Daminion.
  • 4 weeks later...
