Error at "Help -> Go to Daminion Forum" (4.1, 1278)
Egon
after Click at "Help -> Go to Daminion Forum" (see pic_1.jpg) an error appears (see pic_2.jpg)
Here the detailled errortext:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.ComponentModel.Win32Exception: Der angegebenen Datei ist keine Anwendung zugeordnet
at System.Diagnostics.Process.StartWithShellExecuteEx(ProcessStartInfo startInfo)
at System.Diagnostics.Process.Start()
at System.Diagnostics.Process.Start(ProcessStartInfo startInfo)
at System.Diagnostics.Process.Start(String fileName)
at PicaJet.Daminion.ClientCommon.PicaJetEnginePresenter.GotoProductForum(Object sender, ActionExecuteEventArgs e) in c:\DaminionAuto\Code\ClientCommon\Presenters\PicaJetEnginePresenterActions.cs:line 3883
at PicaJet.Daminion.ClientCommon.Action.ExecuteAction(Object sender, ActionExecuteEventArgs e) in c:\DaminionAuto\Code\ClientCommon\Classes\Action.cs:line 397
at PicaJet.Daminion.GUIComponents.ContextMenuGenerator.MainMenuItemClick(Object sender, EventArgs e) in c:\DaminionAuto\Code\GUIComponents\Classes\ContextMenuGenerator.cs:line 595
at System.Windows.Forms.ToolStripItem.RaiseEvent(Object key, EventArgs e)
at System.Windows.Forms.ToolStripMenuItem.OnClick(EventArgs e)
at System.Windows.Forms.ToolStripItem.HandleClick(EventArgs e)
at System.Windows.Forms.ToolStripItem.HandleMouseUp(MouseEventArgs e)
at System.Windows.Forms.ToolStripItem.FireEventInteractive(EventArgs e, ToolStripItemEventType met)
at System.Windows.Forms.ToolStripItem.FireEvent(EventArgs e, ToolStripItemEventType met)
at System.Windows.Forms.ToolStrip.OnMouseUp(MouseEventArgs mea)
at System.Windows.Forms.ToolStripDropDown.OnMouseUp(MouseEventArgs mea)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
at System.Windows.Forms.ToolStrip.WndProc(Message& m)
at System.Windows.Forms.ToolStripDropDown.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.5485 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
Daminion
Assembly Version: 4.1.0.1278
Win32 Version: 4.1.0.1278
CodeBase: file:///C:/Program%20Files%20(x86)/Daminion%20Software/Daminion/Daminion.exe
PicaJet.Daminion.Common
CodeBase: file:///C:/Windows/assembly/GAC_32/PicaJet.Daminion.Common/4.1.0.1278__9f58e3cb9c5c74e7/PicaJet.Daminion.Common.dll
CodeBase: file:///C:/Program%20Files%20(x86)/Daminion%20Software/Daminion/PicaJet.Daminion.ClientCommon.DLL
System
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
Win32 Version: 2.0.50727.5492 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
PicaJet.Daminion.GUIComponents.Win32
CodeBase: file:///C:/Program%20Files%20(x86)/Daminion%20Software/Daminion/PicaJet.Daminion.GUIComponents.Win32.DLL
PicaJet.Daminion.Common.Consts
CodeBase: file:///C:/Program%20Files%20(x86)/Daminion%20Software/Daminion/PicaJet.Daminion.Common.Consts.DLL
Win32 Version: 2.0.50727.5491 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
CodeBase: file:///C:/Program%20Files%20(x86)/Daminion%20Software/Daminion/PicaJet.Daminion.GUIComponents.DLL
PicaJet.Daminion.CommonGuiControls
CodeBase: file:///C:/Program%20Files%20(x86)/Daminion%20Software/Daminion/PicaJet.Daminion.CommonGuiControls.DLL
PicaJet.Daminion.Common.Utils
CodeBase: file:///C:/Program%20Files%20(x86)/Daminion%20Software/Daminion/PicaJet.Daminion.Common.Utils.DLL
PicaJet.Daminion.ImageLibrary
CodeBase: file:///C:/Program%20Files%20(x86)/Daminion%20Software/Daminion/PicaJet.Daminion.ImageLibrary.DLL
DevComponents.DotNetBar
Assembly Version: 7.9.0.2
Win32 Version: 7.9.0.2
CodeBase: file:///C:/Program%20Files%20(x86)/Daminion%20Software/Daminion/DevComponents.DotNetBar.DLL
log4net
Assembly Version: 1.2.10.0
Win32 Version: 1.2.10.0
CodeBase: file:///C:/Program%20Files%20(x86)/Daminion%20Software/Daminion/log4net.DLL
System.Runtime.Remoting
Win32 Version: 2.0.50727.5488 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Runtime.Remoting/2.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
System.Configuration
Win32 Version: 2.0.50727.5483 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
mscorlib.resources
vxvyenjn
PicaJet.Daminion.Common.Localization
CodeBase: file:///C:/Program%20Files%20(x86)/Daminion%20Software/Daminion/PicaJet.Daminion.Common.Localization.DLL
PicaJet.Daminion.MediaProcessingService
CodeBase: file:///C:/Windows/assembly/GAC_32/PicaJet.Daminion.MediaProcessingService/4.1.0.1278__a05df303661f189d/PicaJet.Daminion.MediaProcessingService.dll
PicaJet.Daminion.GUIComponents.VirtualListView
CodeBase: file:///C:/Program%20Files%20(x86)/Daminion%20Software/Daminion/PicaJet.Daminion.GUIComponents.VirtualListView.DLL
PicaJet.Daminion.BusinessObjects
CodeBase: file:///C:/Program%20Files%20(x86)/Daminion%20Software/Daminion/PicaJet.Daminion.BusinessObjects.DLL
Accessibility
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
PicaJet.Daminion.GDIPlusLibrary
CodeBase: file:///C:/Windows/assembly/GAC_32/PicaJet.Daminion.GDIPlusLibrary/4.1.0.1278__f3ea68d2af9506ac/PicaJet.Daminion.GDIPlusLibrary.dll
Daminion.API
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Program%20Files%20(x86)/Daminion%20Software/Daminion/Daminion.API.DLL
n2xv0aiq
PicaJet.Daminion.Service
CodeBase: file:///C:/Program%20Files%20(x86)/Daminion%20Software/Daminion/PicaJet.Daminion.Service.DLL
LogicNP.CryptoLicensing
Assembly Version: 9.0.0.0
Win32 Version: 9.0.0.0
CodeBase: file:///C:/Program%20Files%20(x86)/Daminion%20Software/Daminion/LogicNP.CryptoLicensing.DLL
System.Security
Win32 Version: 2.0.50727.5490 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Security/2.0.0.0__b03f5f7f11d50a3a/System.Security.dll
pkcjumdn
System.Web
CodeBase: file:///C:/Windows/assembly/GAC_32/System.Web/2.0.0.0__b03f5f7f11d50a3a/System.Web.dll
Spring.Core
Assembly Version: 1.2.0.20313
Win32 Version: 1.2.0.20313
CodeBase: file:///C:/Program%20Files%20(x86)/Daminion%20Software/Daminion/Spring.Core.DLL
Common.Logging
Assembly Version: 1.2.0.0
Win32 Version: 1.2.0.0
CodeBase: file:///C:/Program%20Files%20(x86)/Daminion%20Software/Daminion/Common.Logging.DLL
Common.Logging.Log4Net
CodeBase: file:///C:/Program%20Files%20(x86)/Daminion%20Software/Daminion/Common.Logging.Log4net.DLL
PicaJet.Daminion.Service.Utils.Uni
CodeBase: file:///C:/Program%20Files%20(x86)/Daminion%20Software/Daminion/PicaJet.Daminion.Service.Utils.Uni.DLL
Spring.Data
CodeBase: file:///C:/Program%20Files%20(x86)/Daminion%20Software/Daminion/Spring.Data.DLL
PicaJet.Daminion.Service.Client.WCF
CodeBase: file:///C:/Program%20Files%20(x86)/Daminion%20Software/Daminion/PicaJet.Daminion.Service.Client.WCF.DLL
PicaJet.Daminion.ThumbnailStorage
CodeBase: file:///C:/Program%20Files%20(x86)/Daminion%20Software/Daminion/PicaJet.Daminion.ThumbnailStorage.DLL
PicaJet.Daminion.MediaStorage
CodeBase: file:///C:/Program%20Files%20(x86)/Daminion%20Software/Daminion/PicaJet.Daminion.MediaStorage.DLL
PicaJet.Daminion.BusinessObjects.Hibernate
CodeBase: file:///C:/Program%20Files%20(x86)/Daminion%20Software/Daminion/PicaJet.Daminion.BusinessObjects.Hibernate.DLL
CodeBase: file:///C:/Program%20Files%20(x86)/Daminion%20Software/Daminion/PicaJet.Daminion.Service.Utils.DLL
PicaJet.Daminion.Service.Utils.SQLite
CodeBase: file:///C:/Program%20Files%20(x86)/Daminion%20Software/Daminion/PicaJet.Daminion.Service.Utils.SQLite.DLL
antlr.runtime
Assembly Version: 2.7.6.2
Win32 Version: 2.7.6.2
CodeBase: file:///C:/Program%20Files%20(x86)/Daminion%20Software/Daminion/antlr.runtime.DLL
NVelocity
Assembly Version: 0.5.0.0
Win32 Version: 0.5.0.0
CodeBase: file:///C:/Program%20Files%20(x86)/Daminion%20Software/Daminion/NVelocity.DLL
System.Data.SQLite
Assembly Version: 1.0.94.0
Win32 Version: 1.0.94.0
CodeBase: file:///C:/Program%20Files%20(x86)/Daminion%20Software/Daminion/System.Data.SQLite.DLL
System.Data
CodeBase: file:///C:/Windows/assembly/GAC_32/System.Data/2.0.0.0__b77a5c561934e089/System.Data.dll
PicaJet.Daminion.Service.DB
CodeBase: file:///C:/Program%20Files%20(x86)/Daminion%20Software/Daminion/PicaJet.Daminion.Service.DB.DLL
PicaJet.Daminion.Plugins.Core
CodeBase: file:///C:/Windows/assembly/GAC_32/PicaJet.Daminion.Plugins.Core/4.1.0.1278__a061f90d44e3839b/PicaJet.Daminion.Plugins.Core.dll
AutoCADProcessor
CodeBase: file:///C:/Program%20Files%20(x86)/Daminion%20Software/Daminion/MediaProcessors/AutoCADProcessor/AutoCADProcessor.dll
ImageProcessor
CodeBase: file:///C:/Program%20Files%20(x86)/Daminion%20Software/Daminion/MediaProcessors/ImageProcessor/ImageProcessor.dll
MusicProcessor
CodeBase: file:///C:/Program%20Files%20(x86)/Daminion%20Software/Daminion/MediaProcessors/MusicProcessor/MusicProcessor.dll
Office2007Processor
CodeBase: file:///C:/Program%20Files%20(x86)/Daminion%20Software/Daminion/MediaProcessors/Office2007Processor/Office2007Processor.dll
OfficeProcessor
CodeBase: file:///C:/Program%20Files%20(x86)/Daminion%20Software/Daminion/MediaProcessors/OfficeProcessor/OfficeProcessor.dll
PDFProcessor
CodeBase: file:///C:/Program%20Files%20(x86)/Daminion%20Software/Daminion/MediaProcessors/PDFProcessor/PDFProcessor.dll
TextProcessor
CodeBase: file:///C:/Program%20Files%20(x86)/Daminion%20Software/Daminion/MediaProcessors/TextProcessor/TextProcessor.dll
VectorImageProcessor
CodeBase: file:///C:/Program%20Files%20(x86)/Daminion%20Software/Daminion/MediaProcessors/VectorImageProcessor/VectorImageProcessor.dll
VideoProcessor
CodeBase: file:///C:/Program%20Files%20(x86)/Daminion%20Software/Daminion/MediaProcessors/VideoProcessor/VideoProcessor.dll
IEvolution2
Assembly Version: 4.3.0.0
Win32 Version: 4.3.0.0
CodeBase: file:///C:/Program%20Files%20(x86)/Daminion%20Software/Daminion/IEvolution2.DLL
CsXmpToolkit
Assembly Version: 0.3.3.0
Win32 Version: 0.3.3.0
CodeBase: file:///C:/Program%20Files%20(x86)/Daminion%20Software/Daminion/MediaProcessors/ImageProcessor/CsXmpToolkit.DLL
System.Runtime.Serialization.Formatters.Soap
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Runtime.Serialization.Formatters.Soap/2.0.0.0__b03f5f7f11d50a3a/System.Runtime.Serialization.Formatters.Soap.dll
gf2oh-ws
i6achimh
SmartThreadPool
Assembly Version: 2.2.3.0
Win32 Version: 2.2.3.0
CodeBase: file:///C:/Program%20Files%20(x86)/Daminion%20Software/Daminion/SmartThreadPool.DLL
System.Transactions
CodeBase: file:///C:/Windows/assembly/GAC_32/System.Transactions/2.0.0.0__b77a5c561934e089/System.Transactions.dll
PicaJet.Daminion.FileSystemOrganizer
CodeBase: file:///C:/Program%20Files%20(x86)/Daminion%20Software/Daminion/PicaJet.Daminion.FileSystemOrganizer.DLL
protobuf-net
Assembly Version: 1.0.0.278
Win32 Version: 1.0.0.278
CodeBase: file:///C:/Program%20Files%20(x86)/Daminion%20Software/Daminion/protobuf-net.DLL
System.EnterpriseServices
CodeBase: file:///C:/Windows/assembly/GAC_32/System.EnterpriseServices/2.0.0.0__b03f5f7f11d50a3a/System.EnterpriseServices.dll
0yqexlnb
wo76swkr
GMap.NET.Core
Assembly Version: 1.7.0.0
Win32 Version: 1.7
CodeBase: file:///C:/Program%20Files%20(x86)/Daminion%20Software/Daminion/GMap.NET.Core.DLL
GMap.NET.WindowsForms
Win32 Version: 1.7
CodeBase: file:///C:/Program%20Files%20(x86)/Daminion%20Software/Daminion/GMap.NET.WindowsForms.DLL
System.Data.SQLite
Assembly Version: 1.0.96.0
Win32 Version: 1.0.96.0
CodeBase: file:///C:/Users/wir/AppData/Local/GMap.NET/DllCache/SQLite_v96_NET2_x86/System.Data.SQLite.DLL
hsiybmla
te1ejhu_
ghsbmhme
vsomg9dk
50rciquj
3pwbvvyo
System.Management
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Management/2.0.0.0__b03f5f7f11d50a3a/System.Management.dll
xnuoxjw5
1z5jg8dn
ynf4ssjr
z5zaxkms
Interop.WIA
CodeBase: file:///C:/Program%20Files%20(x86)/Daminion%20Software/Daminion/Interop.WIA.DLL
CustomMarshalers
CodeBase: file:///C:/Windows/assembly/GAC_32/CustomMarshalers/2.0.0.0__b03f5f7f11d50a3a/CustomMarshalers.dll
PicaJet.Daminion.ClientCommon.resources
CodeBase: file:///C:/Program%20Files%20(x86)/Daminion%20Software/Daminion/de/PicaJet.Daminion.ClientCommon.resources.DLL
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
