lintujuh Posted November 20, 2014 Report Share Posted November 20, 2014 I updated "readonly" tags in some of my images where some of the EXIF information had been deleted. I used exiftools and the read tags from file in Daminion. The camera make/model where not updated under the corresponding manufacturer but directly to the top level. (not "Canon/Canon EOS 600D", but just "Canon EOS 600D"). This is a similar situation as I reported on keywords. -Juha Quote Link to comment Share on other sites More sharing options...
lintujuh Posted November 20, 2014 Author Report Share Posted November 20, 2014 Also when I update the make/model the "Unknown" the counter doesn't decrease. When I refresh my search the counter is updated. -Juha Quote Link to comment Share on other sites More sharing options...
photowolf Posted November 28, 2014 Report Share Posted November 28, 2014 I also have a problem with the "camera model" tag: the picture says it best: the total number of 32731 pictures doesn't fit to the sum of each camera... under camera model only 7 picture are reported to be from the "EOS 350D". But using the details list (F11) and sort by this camera, there are 60 pictures. Is this related to this bug: https://daminion.net/user-forum/index.php?/topic/2187-raw-files-without-preview-image/ Cheers Wolf Quote Link to comment Share on other sites More sharing options...
photowolf Posted November 28, 2014 Report Share Posted November 28, 2014 I also have a problem with the "camera model" tag: the picture says it best: the total number of 32731 pictures doesn't fit to the sum of each camera... under camera model only 7 picture are reported to be from the "EOS 350D". But using the details list (F11) and sort by this camera, there are 60 pictures. Is this related to this bug: https://daminion.net/user-forum/index.php?/topic/2187-raw-files-without-preview-image/ Cheers Wolf Obviously it's sufficient when rereading the metadata from all files... Quote Link to comment Share on other sites More sharing options...
Russell Posted February 14, 2016 Report Share Posted February 14, 2016 I'd like to be able to edit some of the "Read-Only" tags... specifically the camera make/model. I create panoramic images and the Camera ends up being "Unknown" in the resulting panoramic - but I usually know the actual camera that took the images that comprise the panorama and I'd like to save that into the Metadata. Is there a way Daminion can allow me to do this? (Maybe a special "I know what I'm doing" button before I can do it?). Thanks, Russell Quote Link to comment Share on other sites More sharing options...
Uwe Posted February 14, 2016 Report Share Posted February 14, 2016 Hi Russell, you can't do it with Daminion but the ExifTool does it. You can define a commandline for the ExifTool in the "Open with..." action. I also use the ExifToolGUI to adjust sometimes some metadata. Then "read tags from file" should update the catalog. Regards, Uwe Quote Link to comment Share on other sites More sharing options...
