Volker Posted July 29, 2014 Report Share Posted July 29, 2014 After starting Daminion I can see a very high CPU load on the client. This usually occurs when displaying thumbnails. Selected number of pictures was 541 when I took the screenshot. Quote Link to comment Share on other sites More sharing options...
Murat Posted July 30, 2014 Report Share Posted July 30, 2014 Can you reproduce this issue? Please show me also the "Processes" tab of the Task Manager. Quote Link to comment Share on other sites More sharing options...
Volker Posted July 31, 2014 Author Report Share Posted July 31, 2014 Yes, I can reproduce it: it always ossurs when I open Daminion and a set of thumbnails is being shown. Quote Link to comment Share on other sites More sharing options...
Murat Posted July 31, 2014 Report Share Posted July 31, 2014 Do you work with local or shared catalog? Does Syncing option is turned On? What if you'll switch it Off? Does the problem still there when the Details mode was selected or there are no thumbnails on the screen? Quote Link to comment Share on other sites More sharing options...
Murat Posted August 5, 2014 Report Share Posted August 5, 2014 Do you still experience the same issue with the latest Daminion version? Quote Link to comment Share on other sites More sharing options...
Volker Posted August 5, 2014 Author Report Share Posted August 5, 2014 Hi Murat, I spent the whole weekend upgrading and downgrading because of the issues with 1060. In 1060 I could not see this issue. I couldn't see any thumbnails at all ;-) Will keep you updated on this issue. Volker Quote Link to comment Share on other sites More sharing options...
Murat Posted August 7, 2014 Report Share Posted August 7, 2014 Can you check it with the 1064 build please? Quote Link to comment Share on other sites More sharing options...
Volker Posted September 26, 2014 Author Report Share Posted September 26, 2014 Hi Murat, I'm on build 1070 and can still this issue from time to time. Volker Quote Link to comment Share on other sites More sharing options...
Volker Posted October 4, 2014 Author Report Share Posted October 4, 2014 This is the behaviour with build 1070: Quote Link to comment Share on other sites More sharing options...
Murat Posted October 6, 2014 Report Share Posted October 6, 2014 Please check the issue with the 1087 build. And this this happens again please send me the logs. Quote Link to comment Share on other sites More sharing options...
Volker Posted October 13, 2014 Author Report Share Posted October 13, 2014 I still have this issue with build 1090. I will send you the client logs by email. Quote Link to comment Share on other sites More sharing options...
Murat Posted October 14, 2014 Report Share Posted October 14, 2014 Can you please give us a remote access to your computer? Or provide us more info and screenshots: - Do you work with local or shared catalog? - Is the sync option switched on? Quote Link to comment Share on other sites More sharing options...
Volker Posted October 14, 2014 Author Report Share Posted October 14, 2014 The best time would be tomorrow afternoon around 2 pm (German time). I use a shared catalog. Where can I find the sync option? Can't remember to have it turned on in the past. Quote Link to comment Share on other sites More sharing options...
Volker Posted October 14, 2014 Author Report Share Posted October 14, 2014 Ah... found the sync option. Switching it off has no effect on the behaviour. Quote Link to comment Share on other sites More sharing options...
Volker Posted November 12, 2014 Author Report Share Posted November 12, 2014 Hi Murat, any ideas concerning this problem? Volker Quote Link to comment Share on other sites More sharing options...
Volker Posted November 19, 2014 Author Report Share Posted November 19, 2014 Behaviour is unchanged. Meanwhile I use IrfanView if I want to see my photos. Quote Link to comment Share on other sites More sharing options...
Murat Posted November 29, 2014 Report Share Posted November 29, 2014 Sorry for the delay with responding. We can arrange a new remote session on this Monday. Quote Link to comment Share on other sites More sharing options...
Volker Posted November 29, 2014 Author Report Share Posted November 29, 2014 Would it be ok for you on 6pm German time? Quote Link to comment Share on other sites More sharing options...
Volker Posted November 29, 2014 Author Report Share Posted November 29, 2014 I just upgraded to build 1126 and the behaviour is still the same. Quote Link to comment Share on other sites More sharing options...
Volker Posted December 4, 2014 Author Report Share Posted December 4, 2014 How will we proceed? This screenshot shows the typical behaviour during creating/showing the thumbnails (now with build 1126) Quote Link to comment Share on other sites More sharing options...
rene Posted December 4, 2014 Report Share Posted December 4, 2014 I have a high Memory load instead of a high CPU load Quote Link to comment Share on other sites More sharing options...
Volker Posted December 4, 2014 Author Report Share Posted December 4, 2014 Maybe there's a switch in the software that allows the user to decide whether he wants to have a high memory load or a high CPU load ;-) Quote Link to comment Share on other sites More sharing options...
Volker Posted December 7, 2014 Author Report Share Posted December 7, 2014 Another screenshot from today. I selected 539 pictures and it took several minutes to display the thumbnails. When I start scrolling up and down it's just a nightmare. Quote Link to comment Share on other sites More sharing options...
Murat Posted December 9, 2014 Report Share Posted December 9, 2014 Volker, do you have an active antivirus? Can you try to switch it off? Also, can you please try to switch the Color Management for displaying the thumbnails? Quote Link to comment Share on other sites More sharing options...
Volker Posted December 15, 2014 Author Report Share Posted December 15, 2014 Hello Murat, Avira AntiVir real time scanner is turned off. And the color management is also turned off. Regards, Volker Quote Link to comment Share on other sites More sharing options...
