xeta Posted January 19, 2014 Report Share Posted January 19, 2014 Is there any possibility to disable the notification sound when saving an element? Quote Link to comment Share on other sites More sharing options...
Cactus Posted January 23, 2014 Report Share Posted January 23, 2014 Is there any possibility to disable the notification sound when saving an element? And on selecting item in dropdown lists like People, when you selecting by keyboard Up and Down arrow keys. Quote Link to comment Share on other sites More sharing options...
Murat Posted January 23, 2014 Report Share Posted January 23, 2014 And on selecting item in dropdown lists like People, when you selecting by keyboard Up and Down arrow keys. Fixed. Is there any possibility to disable the notification sound when saving an element? How to reproduce it? I change a tag and then press Ctrl + S or select another item - no sound while saving tags... Quote Link to comment Share on other sites More sharing options...
kalain Posted January 23, 2014 Report Share Posted January 23, 2014 How to reproduce it? I change a tag and then press Ctrl + S or select another item - no sound while saving tags... I guess this is when you attribute (validate) a tag for a thumbnail. This is now (in build 949) the only beep you can hear. Quote Link to comment Share on other sites More sharing options...
Murat Posted January 24, 2014 Report Share Posted January 24, 2014 I guess this is when you attribute (validate) a tag for a thumbnail. This is now (in build 949) the only beep you can hear. Can you please record me a screencast video with enabled sound? Quote Link to comment Share on other sites More sharing options...
kalain Posted January 24, 2014 Report Share Posted January 24, 2014 Can you please record me a screencast video with enabled sound? Send via email. There is a sound when you attribute a keyword, people, ... but I do not consider this as a bug or a disadvantage. Quote Link to comment Share on other sites More sharing options...
Murat Posted January 24, 2014 Report Share Posted January 24, 2014 Thanks! I hear it now :) Quote Link to comment Share on other sites More sharing options...
Jacal Posted January 24, 2014 Report Share Posted January 24, 2014 Hi! In build 950, that sound plays every time I hit "Enter" in Properties panel (to add another keyword, category etc.). Official builds are always silent here. Quote Link to comment Share on other sites More sharing options...
Murat Posted January 25, 2014 Report Share Posted January 25, 2014 950 build is the last one with annoying sounds in the Properties panel Quote Link to comment Share on other sites More sharing options...
