Bug Report - Folder Rescan Problem
Mardon
After using build 751 a little longer, There does seem to be a problem with the Rescan function. It seems to randomly miss files. Sometimes it works OK, other times it doesn't import anything and other times it imports only some of the files.
I did a test Rescan of the folder: ...\20090810\DNG It contains 159 DNG files and 11 WAV files.
The Folder Rescan Started at 20:10
The Rescan ended at 20:15
159 DNG files and 11 WAV files should have been added. Instead, 11 WAV files were added but only 21 DNG files.
I have attached a screen shot of the folder in Windows Explorer and the Daminion client as well as copies of the relevant server and client logs.
ServerLogs_RescanError_Build751.zip
Client_log_Rescan_Error_Build_751.txt
