cincytriguy Posted September 27, 2023 Report Share Posted September 27, 2023 I've followed the documentation to create a scheduled task to backup my catalog daily, but the task isn't running. I've updated backup_config.bat, and when I manually execute Backup Daminion Catalog.bat, I get a successful backup. But the scheduled task is not running at the scheduled time, and if I right-click the scheduled task and select "Run", nothing happens. I was hoping the task scheduler would dump an error to the Windows event logs but I can't find anything. Is there a way to determine why the scheduled task isn't running? Quote Link to comment Share on other sites More sharing options...
Daria Kotilainen Posted September 27, 2023 Report Share Posted September 27, 2023 Hi Jason, When adding the task to the task scheduler, did you specify the folder to run the task in? If so, in that folder you'll have a subfolder named Backup and in there you can find the logs file Let me know if it is there? Kind regards, Daria Quote Link to comment Share on other sites More sharing options...
cincytriguy Posted September 27, 2023 Author Report Share Posted September 27, 2023 Hi Daria. I do have the "start in" pointing at the location of the batch files. For example, it looks like this: Program/script: "C:\Users\Public\Documents\Daminion Backups\Backup Daminion Catalog.bat" Start in: "C:\Users\Public\Documents\Daminion Backups\" Is this correct? Quote Link to comment Share on other sites More sharing options...
Daria Kotilainen Posted September 27, 2023 Report Share Posted September 27, 2023 Yep, this is correct. Please check the logs file in there Quote Link to comment Share on other sites More sharing options...
cincytriguy Posted September 27, 2023 Author Report Share Posted September 27, 2023 Hi Daria. When I manually run Backup Daminion Catalog.bat it generates the following log entry in backup.log: 2023-09-27_08-59: The Daminion database was successfully dumped to But when I try to run the scheduled task no log entry is generated. Quote Link to comment Share on other sites More sharing options...
Daria Kotilainen Posted September 28, 2023 Report Share Posted September 28, 2023 Hi Jason, would you be willing to send me screenshots of each tab in your scheduled task and backup config .bat file? If you'd prefer not to attach them here, you can drop them to me by email Kind regards, Daria Quote Link to comment Share on other sites More sharing options...
cincytriguy Posted September 29, 2023 Author Report Share Posted September 29, 2023 Absolutely. I'll email them to you as it will be easier for me to keep track of. Thank you! Jason Quote Link to comment Share on other sites More sharing options...
