Oleg.Ross Posted June 17, 2022 Report Share Posted June 17, 2022 Starting from 7.6.0.2725+ we have added the "DoNotResize" setting for Face Recognition to the catalog configuration file. How it works: Default setting is DoNotResize="false". The face recognition process can generally be described with the following steps: 1.Generate Mid-size preview (2000x2000) 2.Resize to 1000x1000 3.Start the recognition process We are using Dlib for face recognition and the library has this limitation: Quote Does not detect small faces as it is trained for minimum face size of 80×80. Thus, you need to make sure that the face size should be more than that in your application. Warning! When resize is disabled, face recognition process can take more time and use more CPU power. It's not recommended to disable it for large catalogs. How-to change the setting: 1.Log in to the system as administrator 2.Stop Daminion server 3. Go to server dir ( ex. C:\Program Files(x86)\Daminion Software\Daminion Server\ 4.Find catalog.config and copy to desktop 5.Open catalogs.config with Notepad 6.Find string - doNotResizeFaces="false" and change "false" to "true" 7.Save 8.Copy catalog.config back to server dir (overwrite) 10.Restart Pc to apply changes. 9.Start server This setting will be applied only for new imported photos. There is a visual explanation in pdf file: Faces.pdf Quote Link to comment Share on other sites More sharing options...
rene Posted November 14, 2022 Report Share Posted November 14, 2022 Hello Oleg, I will give it a try. but how to apply it to already imported photos? Quote Link to comment Share on other sites More sharing options...
Oleg.Ross Posted November 15, 2022 Author Report Share Posted November 15, 2022 18 hours ago, rene said: Hello Oleg, I will give it a try. but how to apply it to already imported photos? You can't do that now. But in the new version 7.9 we will add this feature. Quote Link to comment Share on other sites More sharing options...
rene Posted November 16, 2022 Report Share Posted November 16, 2022 22 hours ago, Oleg.Ross said: You can't do that now. But in the new version 7.9 we will add this feature. ok thank you! Hoping for folder wise face recognition soon Quote Link to comment Share on other sites More sharing options...
kalain Posted May 15, 2024 Report Share Posted May 15, 2024 Hi, Due to poor face recognition (> 80*80 pixels) under 9.0 - 3480, looks like this post and faces.pdf file is out dated. I can find catalogs.config in C:\Program Files\Daminion Software\Daminion Server\ not in C:\Program Files(x86)\Daminion Software\Daminion Server\ but inside file no such string : doNotResizeFaces="false" Here is content of catalogs.config : <?xml version="1.0" encoding="utf-8" ?> <ServerCatalogs defaultThumbnailsStorePath="C:\ProgramData\Daminion Software\Daminion Server\Thumbnails"> <Catalogs> <Catalog catalogName="NetCatalog" mediaStorePath="D:\Daminion Server " thumbnailsStorePath="C:\ProgramData\Daminion Software\Daminion Server\Thumbnails\NetCatalog" videoStorePath="C:\ProgramData\Daminion Software\Daminion Server\Video" webaccess="true" databasePort="5432" transportPort="8082" fileTransportPort="8084" databasePassword="postgres" /> </Catalogs> </ServerCatalogs> Quote Link to comment Share on other sites More sharing options...
Oleg.Ross Posted May 15, 2024 Author Report Share Posted May 15, 2024 2 hours ago, kalain said: Hi, Due to poor face recognition (> 80*80 pixels) under 9.0 - 3480, looks like this post and faces.pdf file is out dated. I can find catalogs.config in C:\Program Files\Daminion Software\Daminion Server\ not in C:\Program Files(x86)\Daminion Software\Daminion Server\ but inside file no such string : doNotResizeFaces="false" Here is content of catalogs.config : <?xml version="1.0" encoding="utf-8" ?> <ServerCatalogs defaultThumbnailsStorePath="C:\ProgramData\Daminion Software\Daminion Server\Thumbnails"> <Catalogs> <Catalog catalogName="NetCatalog" mediaStorePath="D:\Daminion Server " thumbnailsStorePath="C:\ProgramData\Daminion Software\Daminion Server\Thumbnails\NetCatalog" videoStorePath="C:\ProgramData\Daminion Software\Daminion Server\Video" webaccess="true" databasePort="5432" transportPort="8082" fileTransportPort="8084" databasePassword="postgres" /> </Catalogs> </ServerCatalogs> Hello the setting is displayed in the GUI. By default the checkbox is checked, if you want more accurate recognition uncheck the checkbox and restart the server. This setting is equivalent to the one described in the first post. Quote Link to comment Share on other sites More sharing options...
kalain Posted May 16, 2024 Report Share Posted May 16, 2024 Hi Oleg, Thanks for the tip, this improved results by there is still some strange issues. No way to find second person as shown below, even after clearing informations and process again !! In my case, I'd say that face recognition is working at 40%. 60% missing are like example above !! Not extreme or difficult face to find. Quote Link to comment Share on other sites More sharing options...
