Tschens Posted December 28, 2020 Report Share Posted December 28, 2020 Hello, Is there any way to remove a (wrong) auto-tag from an image? Have been searching for 15 minutes now - no chance via right click or menu. 😞 Thx Jens Quote Link to comment Share on other sites More sharing options...
Katerina Karpenko Posted December 28, 2020 Report Share Posted December 28, 2020 Hello, To remove auto-tag from an image you can click the x-button on the wrong tag in the Properties panel. It's also the way to remove auto-tags in the web client. (screen 1) Or you can select an item and choose "Remove "Wrong auto-tag" from (X) selected items" in the menu in the Tags Panel. (screen2) Kind Regards, Kate Quote Link to comment Share on other sites More sharing options...
Tschens Posted December 28, 2020 Author Report Share Posted December 28, 2020 Thanks Kate, I was missing both options. I could change the settings to show "Auto Tags" in the file propoerties (standard is unselected), now its there and I can remove wrong tags. However, this is more cumbersome than the other option. But the other option does not work for me: The two options "Assing TAG to selected item" and "Remove TAG from selected item" when clicking right mouse button are missing! I have these options for Persons and Keywords, but not for Auto Tags. Working with beta 2344. Any idea? Regards, Jens Quote Link to comment Share on other sites More sharing options...
Katerina Karpenko Posted December 28, 2020 Report Share Posted December 28, 2020 I'm working with the same version. What user are you using for work? Could you please send me a screenshot or video where you select any item and open the right-click menu in Tag Panel? Regards Quote Link to comment Share on other sites More sharing options...
Tschens Posted December 28, 2020 Author Report Share Posted December 28, 2020 Working as admin. Just sent a PM with Dropbox link. Thanks for your help! Quote Link to comment Share on other sites More sharing options...
Tschens Posted December 30, 2020 Author Report Share Posted December 30, 2020 Problem solved by Daminion team via pm. Thanks a lot. Quote Link to comment Share on other sites More sharing options...
Tschens Posted December 31, 2020 Author Report Share Posted December 31, 2020 Another question which fits into this thread: Obviously, it is not possible to Re-Tag a previously auto-tagged file via auto-tagging. When the autotags are removed manually, they never come back if i try to re-tag them. I have to generate a copy of the file in order to re-tag it. Is this a limitation from google or a Daminion-based issue? Regards, Jens Quote Link to comment Share on other sites More sharing options...
