Build 2233
Pictor
2 hours ago, Pictor said:
But the downloaded installation file is build 2232.
Hi Pictor, I did not try to download the standalone version, but when you download the server version, you get a zip-file containing DaminionClientSetup-6.7.0.2233.exe, which does indeed install build 2233. At least in the past, this was identical to the standalone version.
Hi Wilfried,
thanks for your info. 👍
But Daminion team should be able to provide the right version. Because that way I have to download about 400 MB for the trash can.
And just today some figures about the environmental impact of internet usage are published.
But thanks again. If the correct link for download is not set on Friday, I will try the "Server" version. 😉
Pictor
