Display only if it has less than 2 keywords
kalain
when you choose 'is not empty', it's supposed keyword qty is > 0)
when you choose 'is empty' it's supposed keyword qty = 0.
Adding 'Qty >' or 'Qty <=' would be nice in order to ckeck which item is well documented or which is less documented and needs some more keywords.
Having this possibility gives a better way to optimise how your items are described with keywords.
Hello Kalain, I can suggest you switch to Daminion server - in the latest version we have a feature named Required Metadata. You can activate it and select 2 required keywords. All files that have less keywords will be displayed in a special area. This can be a workaround for now as the change in search parameters is not planned for the nearest future for the desktop version.
Kind regards,
Daria
