Egon Posted April 21, 2020 Report Share Posted April 21, 2020 Hello, I have marked several files. Then i search for a certain numeric value of a tag in the catalog tag panel. The result is: the marked files have been color-coded. Example: I searched for 48. Then I typed 48 and the color marking of the files is brown. That's funny. Egon Quote Link to comment Share on other sites More sharing options...
WilfriedB Posted April 21, 2020 Report Share Posted April 21, 2020 3 hours ago, Egon said: Then I typed 48 and the color marking of the files is brown. Egon, the number 8 is the shortcut to select color label "Brown" (same like Ctrl+8 sets a rating and F or X a flag). This means, at the time, you typed 48, the focus what not the Quick Search field on top of the display, but the thumbnail area. This also happened to me in the past several times. Quote Link to comment Share on other sites More sharing options...
Daria Kotilainen Posted April 21, 2020 Report Share Posted April 21, 2020 Hi Egon, If you select the files and then click the search bar in the tags panel to start typing the number value, the focus will be shifted from the thumbnail area to the tags panel and the files will not be color-coded Kind regards Daria Quote Link to comment Share on other sites More sharing options...
Egon Posted April 22, 2020 Author Report Share Posted April 22, 2020 Hello Daria, thank you. This runs. Greetings Egon Quote Link to comment Share on other sites More sharing options...
