Daria Kotilainen Posted December 19, 2019 Report Share Posted December 19, 2019 Hi guys, I'm sorry to tell you that we've discovered an issue with auto-sync in the latest build - not all the tags are written into the files metadata. Please use the manual synchronization until it gets fixed Kind regards, Daria Quote Link to comment Share on other sites More sharing options...
WilfriedB Posted December 19, 2019 Report Share Posted December 19, 2019 Not sure, if this happens always, but I found cases when the changed tag is not written into metadata. It happens, when you rename a tag and the new tag needs to be merged with an existing on. It seems to work fine, if you rename a tag and the resulting new tag does not exist yet (i.e. no merge necessary). I just tried the above again in Build 203. Quote Link to comment Share on other sites More sharing options...
Daria Kotilainen Posted December 23, 2019 Author Report Share Posted December 23, 2019 Hi Wilfried, yes, there are issues with auto-sync. If you do the same and sync the tags manually (write tags to file), are the changes saved into the metadata? Daria Quote Link to comment Share on other sites More sharing options...
WilfriedB Posted December 23, 2019 Report Share Posted December 23, 2019 3 hours ago, Daria Kotilainen said: If you do the same and sync the tags manually (write tags to file), are the changes saved into the metadata? Yes, it they are. Once you found such a mismatch, it is easy to solve, but the real difficulty is to find all images where auto-sync failed in the past . Quote Link to comment Share on other sites More sharing options...
Daria Kotilainen Posted December 23, 2019 Author Report Share Posted December 23, 2019 That's true 😞 the only way would be to create a backup, turn auto-sync off, select all files (or folder by folder ) and write the tags into the files manually Daria Quote Link to comment Share on other sites More sharing options...
