edisso10018 Posted July 8, 2018 Report Share Posted July 8, 2018 Is there a way to preserve the zoom factor for the map window? After a restart of Daminion the map always show the whole world... Quote Link to comment Share on other sites More sharing options...
Daria Kotilainen Posted July 9, 2018 Report Share Posted July 9, 2018 Is there a way to preserve the zoom factor for the map window? After a restart of Daminion the map always show the whole world... Hi Edisso, Tested on v5.9 - both server and local. If select a file which does have GPS coordinate and locate it on the map (zoom in map and check option to zoom to selected files in the map setting in the upper right corner), then close the catalog\program and reopen it, map view is zoomed according to the position of the latest selected file on the map. Kind regards, Daria Quote Link to comment Share on other sites More sharing options...
edisso10018 Posted July 10, 2018 Author Report Share Posted July 10, 2018 Yep, you're right. Hmm. Thanks anyway. Quote Link to comment Share on other sites More sharing options...
