1763 - crash if click on a thumbnail
Uwe
Hi there,
Same here, error log shows:
2018-03-04 14:24:25,674 [19] ERROR PicaJet.Daminion.Service.Utils.GetMediaItemDataCommand [(null)] - Error: (133) - 1957838
Npgsql.NpgsqlException:
missing FROM-clause entry for table "files"
Severity: ERROR
Code: 42P01
  at Npgsql.NpgsqlState.<ProcessBackendResponses>d__0.MoveNext() in c:\dev\TeamCity\buildAgent\work\45caad201a245970\Npgsql\Npgsql\NpgsqlState.BackendResponse.cs:line 310
  at Npgsql.ForwardsOnlyDataReader.GetNextResponseObject(Boolean cleanup) in c:\dev\TeamCity\buildAgent\work\45caad201a245970\Npgsql\Npgsql\NpgsqlDataReader.cs:line 1158
  at Npgsql.ForwardsOnlyDataReader.GetNextRowDescription() in c:\dev\TeamCity\buildAgent\work\45caad201a245970\Npgsql\Npgsql\NpgsqlDataReader.cs:line 1176
  at Npgsql.ForwardsOnlyDataReader.NextResultInternal() in c:\dev\TeamCity\buildAgent\work\45caad201a245970\Npgsql\Npgsql\NpgsqlDataReader.cs:line 1386
  at Npgsql.ForwardsOnlyDataReader..ctor(IEnumerable`1 dataEnumeration, CommandBehavior behavior, NpgsqlCommand command, NotificationThreadBlock threadBlock, Boolean preparedStatement, NpgsqlRowDescription rowDescription) in c:\dev\TeamCity\buildAgent\work\45caad201a245970\Npgsql\Npgsql\NpgsqlDataReader.cs:line 1010
  at Npgsql.NpgsqlCommand.GetReader(CommandBehavior cb) in c:\dev\TeamCity\buildAgent\work\45caad201a245970\Npgsql\Npgsql\NpgsqlCommand.PrepareExecute.cs:line 279
  at Npgsql.NpgsqlCommand.ExecuteReader(CommandBehavior cb) in c:\dev\TeamCity\buildAgent\work\45caad201a245970\Npgsql\Npgsql\NpgsqlCommand.PrepareExecute.cs:line 234
  at Npgsql.NpgsqlCommand.ExecuteDbDataReader(CommandBehavior behavior) in c:\dev\TeamCity\buildAgent\work\45caad201a245970\Npgsql\Npgsql\NpgsqlCommand.PrepareExecute.cs:line 181
  at System.Data.Common.DbCommand.ExecuteReader()
  at PicaJet.Daminion.Service.DbCommandWrapper.ExecuteReader() in c:\DaminionAuto\Code\Service.DB\DbCommandWrapper.cs:line 48
  at PicaJet.Daminion.Service.Utils.LinearValuesHandler.ProcessValues(MediaItemLocalEntity mediaItem, IList`1 namespaceItems, DbConnection connection, UniversalCatalogService service) in c:\DaminionAuto\Code\Service.Utils.Uni\Command\LinearValuesHandler.cs:line 236
  at PicaJet.Daminion.Service.Utils.TagsWorkerDbHelper.GetOrUpdateMediaItemFromDB(Int64 mediaItemId, MediaItemLocalEntity mediaItem, IList`1 indexedTags, IList`1 namespaceItems, ITagsWorker tagsWorker, DbConnection connection) in c:\DaminionAuto\Code\Service.Utils.Uni\Helper\TagsWorkerDbHelper.cs:line 638
  at PicaJet.Daminion.Service.Utils.AnotherTagsWorker.GetMediaItem(Int64 mediaItemId, IList`1 indexedTags, IList`1 namespaceItems, DbConnection connection) in c:\DaminionAuto\Code\Service.Utils.Uni\AnotherTagsWorker.cs:line 680
  at PicaJet.Daminion.Service.Utils.GetMediaItemDataCommand.Start(DbConnection connection) in c:\DaminionAuto\Code\Service.Utils.Uni\Command\GetMediaItemDataCommand.cs:line 58
  at PicaJet.Daminion.Service.Utils.DatabaseCommand.Start() in c:\DaminionAuto\Code\Service.Utils.Uni\DatabaseCommand.cs:line 110
  at PicaJet.Daminion.Service.Utils.DatabaseCommand.Process() in c:\DaminionAuto\Code\Service.Utils.Uni\DatabaseCommand.cs:line 50
Regards
