Egon Posted November 16, 2017 Report Share Posted November 16, 2017 Hello, when I click to one file which has gps coordinates the right map detail is displayed, but not the exact location with the count. Egon Quote Link to comment Share on other sites More sharing options...
WilfriedB Posted November 17, 2017 Report Share Posted November 17, 2017 Works for me with Build 1736. Did you try only Google or are you seeing the same behavior with Bing? I noticed, the time needed to show the markers on the map varies often. Quote Link to comment Share on other sites More sharing options...
Egon Posted November 17, 2017 Author Report Share Posted November 17, 2017 It does not work with Google and Bing. Quote Link to comment Share on other sites More sharing options...
Egon Posted November 18, 2017 Author Report Share Posted November 18, 2017 Where can I get Build 1736 standalone? Quote Link to comment Share on other sites More sharing options...
WilfriedB Posted November 18, 2017 Report Share Posted November 18, 2017 Where can I get Build 1736 standalone? Daria published it a couple of days ago here. This is the direct link: https://drive.google.com/open?id=1p-6Esez3aE3Pxnv0u9Ob3xb6PWT_1KR9 Quote Link to comment Share on other sites More sharing options...
Egon Posted November 20, 2017 Author Report Share Posted November 20, 2017 Now I installed Build 1736 and nothing is better. I select a file with geo tags and in the map is no marker and count. For me the work with the map has become worse (since 1726). Quote Link to comment Share on other sites More sharing options...
Daria Kotilainen Posted November 24, 2017 Report Share Posted November 24, 2017 Hi Egon, What is your Windows version? Cannot reproduce neither on Win7, nor Win10, both standalone and server work normal - pins are displayed on the map. Regards, Daria Quote Link to comment Share on other sites More sharing options...
WilfriedB Posted November 26, 2017 Report Share Posted November 26, 2017 As I said above, it also does work for me. However, many times I experience varying response times from short to extremely long. No idea what really causes the differences. Maybe just a matter of waiting patiently ....? Quote Link to comment Share on other sites More sharing options...
