lintujuh Posted April 26, 2017 Report Share Posted April 26, 2017 Hi, If I update a thumbnail (Ctrl-B) of an image that is also in the Tray, the thumbnail in the Tray is not updated. If I remove the item from the Tray and re-insert it, I still get the old thumbnail. It was updated after some time, when I had displayed the few times the full size image. -Juha Quote Link to comment Share on other sites More sharing options...
Daria Kotilainen Posted April 28, 2017 Report Share Posted April 28, 2017 Hi, If I update a thumbnail (Ctrl-B) of an image that is also in the Tray, the thumbnail in the Tray is not updated. If I remove the item from the Tray and re-insert it, I still get the old thumbnail. It was updated after some time, when I had displayed the few times the full size image. -Juha Hi Juha, Reproduced and registered (#4560) Thank you for reporting! Regards, Daria Quote Link to comment Share on other sites More sharing options...
