Paul Barrett Posted December 23, 2016 Report Posted December 23, 2016 In the standalone version there are two distinct operations when you update a tag. 1. A message 'Assigning tags' appears for a period (the more images the longer it takes, obviously) - this is when the catalog is updated I believe 2. Then auto-sync writes the changes to file. On the server version that first stage seems to almost not happen or it's so fast that I miss it when I blink. Is that expected behaviour? Thanks Paul Quote
Uwe Posted December 24, 2016 Report Posted December 24, 2016 Hello Paul, it's the same in the Server version. You should see the modal Window "Assigning Tags" (with a green progress information) - depending on the number of handled items. This is like a "inizialisation process" of the synchronization activity you can see in the bottom of the Browser Window. Depending on the number and the size of the files it can be very fast and you see nothing. Regards, Uwe Quote
Paul Barrett Posted December 24, 2016 Author Report Posted December 24, 2016 Hello Paul, it's the same in the Server version. You should see the modal Window "Assigning Tags" (with a green progress information) - depending on the number of handled items. This is like a "inizialisation process" of the synchronization activity you can see in the bottom of the Browser Window. Depending on the number and the size of the files it can be very fast and you see nothing. Regards, Uwe Okidoki. Thanks Merry Christmas Quote
