Paul Barrett Posted November 3, 2016 Report Share Posted November 3, 2016 I have customised the content of the properties panel but there is a disparity between the fields I want to appear in the Image section, and what actually appears. (screenshot attached) I have looked in as many places as I can think of but can see no help on this. Can someone point me in the right direction please? Thanks so much -Paul Quote Link to comment Share on other sites More sharing options...
Uwe Posted November 3, 2016 Report Share Posted November 3, 2016 Hello Paul, did you checked if the selected item has the missing tags in its EXIF/XMP metadata section? You can do it by the action "show all metadata". Only existing metadata are shown in the image section of the Properties Panel. Regards, Uwe Quote Link to comment Share on other sites More sharing options...
Paul Barrett Posted November 3, 2016 Author Report Share Posted November 3, 2016 Ah, that's exactly my issue. I wanted to enter missing camera model information. So the only way I can do that is to use exiftool, right? It's not editable in Daminion? - Paul Quote Link to comment Share on other sites More sharing options...
Uwe Posted November 3, 2016 Report Share Posted November 3, 2016 So the only way I can do that is to use exiftool, right? It's not editable in Daminion? Yes, that's correct. These are "technical read-only metadata". Daminion doesn't write these information. But you can use the "Open with" option of Daminion to call the ExifTool and to write the metadata. Then you have to call the action "Read Tags from file" to update the Daminion database. I use e.g. the following command lines to write Maker, Model and Lens metadata by the ExifTool. Regards, Uwe Quote Link to comment Share on other sites More sharing options...
Paul Barrett Posted November 3, 2016 Author Report Share Posted November 3, 2016 Cool.. Thanks as always! :) - Paul Quote Link to comment Share on other sites More sharing options...
