Photon Posted June 7, 2016 Report Share Posted June 7, 2016 Hello, I am using standalone version 4.6.0 (Build 1470) and I possibly found a bug in the export function, unless I used this function the wrong way: I want to export pictures into a specific folder with resizing and deleting all metatags. So I created my own export profile, setting the size options and for the "adding metatags" I set "none" (in German version: keine). Then I exported the pics. Checking the pics after that, shows: size is ok but all metatags are still there (GeoTags, categories, keywords.... ) - as far as I understand the setting "none" there should not be any metatags anymore. Or did I misunderstood this ? Thanks for any help! Greetings, Photon Quote Link to comment Share on other sites More sharing options...
Uwe Posted June 7, 2016 Report Share Posted June 7, 2016 Hello Photon, what was the format of your source and destination file? Please send a screenshot of your Preferences (im Menü: Bearbeiten->Einstellungen->Metadata schreiben). Regards, Uwe Quote Link to comment Share on other sites More sharing options...
Photon Posted June 7, 2016 Author Report Share Posted June 7, 2016 Hallo, Eingabe- und Ausgabeformat: jeweils JPG. Die Screenshots der beiden Menüs habe ich angehängt. Bei den Einstellungen "Metadaten schreiben" habe ich zum Test auf "Exif/IPTC und XMP" umgestellt, das Resultat ist das Gleiche geblieben. Viele Grüße, Photon Quote Link to comment Share on other sites More sharing options...
Uwe Posted June 7, 2016 Report Share Posted June 7, 2016 Hello, confirmed also for the Server version using the JPG for source and destination format. But there are some other issues. 01. A TIF file_01 created by a Canon flatbed scanner: export and convert to JPG (adjusted size 320x320, no metadata)= all metadata remain in the final JPG file 02. A TIF file_02 created by panaorama software from DNG files: same conversion like case 01 = except some EXIF metadata no other metadata in the final JPG file. 03: A DNG file_03 converted like case 01 = some Exif metadata and the GEO coordinates remain in the final JPG Tested with build 1471. Regards, Uwe Quote Link to comment Share on other sites More sharing options...
Murat Posted June 7, 2016 Report Share Posted June 7, 2016 Fixed. Quote Link to comment Share on other sites More sharing options...
Photon Posted June 7, 2016 Author Report Share Posted June 7, 2016 I just downloaded build 1472 and tested it. It works now! Thanks for that fast fix! Quote Link to comment Share on other sites More sharing options...
