fehlow Posted March 25, 2016 Report Share Posted March 25, 2016 Hi, I am geo-referencing files with Geosetter. I want to update the Daminion catalog with the externally entered information (Place, latitude, longitude). I am choosing Rescan with option "Update Catalog with Modified Files" ticked. Unfortunately no data are imported. When I am using "Read Tags from File" from the sync menu this will do the job but is much slower. What is the Rescan option for, then? Quote Link to comment Share on other sites More sharing options...
Jacal Posted March 26, 2016 Report Share Posted March 26, 2016 Rescan should find added and changed metadata even with unchanged file timestamp, and this bug was fixed at least once in the past. I have also noticed that it currently doesn't work as expected. Quote Link to comment Share on other sites More sharing options...
Murat Posted March 27, 2016 Report Share Posted March 27, 2016 "Rescan" works only when file modified date or file size were changed. "Read Tags from File" forces importing metadata not matter whether a file was changed or no. Quote Link to comment Share on other sites More sharing options...
Jacal Posted March 27, 2016 Report Share Posted March 27, 2016 Adding a couple of tags using third party editor (like Geosetter) slightly changes the file size, but when time remains unchanged, it can happen that the changes are not recognized during rescan. Quote Link to comment Share on other sites More sharing options...
fehlow Posted March 27, 2016 Author Report Share Posted March 27, 2016 Thanks for your answers. It seems that most (or only ?) relevant option that Rescan will update information is modified file date. File size did obviously not matter in the cases I have described (and I have just tested again). I have found out that in Geosetter the option "Preserve File Date and Time when Saving Changes" was chosen and that was the reason for Daminion not recognizing the new metadata. However, because creation date etc. are stored in EXIF/IPTC data the file date is not relevant anyway. When I witch the option off everything works fine. Quote Link to comment Share on other sites More sharing options...
Jacal Posted March 27, 2016 Report Share Posted March 27, 2016 But id did work for some time, recognizing changes in file size. It looks like a regression. Be well! Quote Link to comment Share on other sites More sharing options...
