jsolvang Posted January 28, 2016 Report Share Posted January 28, 2016 A moment ago I bought a license for the Standard standalone Daminion. When I copied the password line number two in the registration window tells that I can import 75.000 files and that the program is active. Unfortunately the bottom line says that I can only import 25.000 files. The very top left part of the browser says License Type: Basic. Restart did not help. I have not tried reinstallation. I have a problem since I need the room for files. Regards Jens Solvang Quote Link to comment Share on other sites More sharing options...
Sedat Posted January 29, 2016 Report Share Posted January 29, 2016 Hello Jens, do you may have two licenses installed now? If that is the case just delete the Basic license so only your new Daminion-Standard license is listed and active in the license list box. And restart Daminion after deleting the old license. However a reinstallation of Daminion is not necessary. 1 Quote Link to comment Share on other sites More sharing options...
rene Posted January 30, 2016 Report Share Posted January 30, 2016 check the licenses again and remove the old one 1 Quote Link to comment Share on other sites More sharing options...
